NAT or routing problem
Moudar
I got this topology here:
I got my Windows PC with IP 192.168.10.128 and i have configured it with a static route:
Persistent Routes:
  Network Address          Netmask  Gateway Address  Metric
    100.100.100.1  255.255.255.255   192.168.10.130       1
    100.100.100.2  255.255.255.255   192.168.10.130       1
If i ping 100.100.100.1 it works fine but if i ping 100.100.100.2 it does not.
Here is how the NAT configuration looks like on the router:
interface GigabitEthernet0/0
 ip address 100.100.100.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
 media-type rj45
interface GigabitEthernet0/1
 ip address 192.168.10.130 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
 media-type rj45
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 2 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.10.1
ip ssh version 2
access-list 1 permit 100.100.100.0 0.0.0.255
access-list 2 permit 192.168.10.0 0.0.0.255
If i ping 100.100.100.2 from the router it works fine!
So the question is why I cannot ping 100.100.100.2 from my PC?
Any ideas!
ammahend
try this config for NAT
Router(config)# interface GigabitEthernet0/1
Router(config-if)# ip address 192.168.10.130 255.255.255.0
Router(config-if)# ip nat inside
Router(config-if)# no shutdown
Router(config)# interface GigabitEthernet0/0
Router(config-if)# ip address 100.100.100.1 255.255.255.0
Router(config-if)# ip nat outside
! Create an access list to match the inside network
Router(config)# access-list 1 permit 192.168.10.0 0.0.0.255
! Enable NAT overload (PAT) to translate private IPs to the public IP
Router(config)# ip nat inside source list 1 interface GigabitEthernet0/0 overload
-hope this helps-
Hello
make sure that host you are trying to ping has a default-gateway
Kind Regards
Paul
M02@rt37
Hello @Moudar
Do adjustements;
vIOS interface Gi0/1 => ip nat inside and interface Gi0/0 => ip nat outside
Next
Delete these two commands:
ip nat inside source list 2 interface GigabitEthernet0/1 overload and ip route 0.0.0.0 0.0.0.0 192.168.10.1:
no ip nat inside source list 2 interface GigabitEthernet0/1 overload
no ip route 0.0.0.0 0.0.0.0 192.168.10.1
After that vPC should ping 10.100.100.2
Best regards
