NAT over VRF problem
WillD2013
Good day, Thanks in advance for reading this note.
I'm about to pull out my hair trying to figure out this problem on ISR G2 1941. I'm running a VRF that uses NAT to access the WAN/Public network. I'm not able to access the WAN/Public network thru NAT from the Local LAN in the VRF.
Setup -
(Public Interface) 192.168.33.28 (Gateway 192.168.33.1) Interface G0/0 on ISR G2
(ISR G2 Gateway) 172.25.0.1 (VRF T172) Interface G0/1.172
(Local Lan) 172.25.0.0/24 (VRF T172) - Host 172.25.0.3
Problem -
I can ping the ISR and WAN interface from the host (172.25.0.2) however not able to NAT thru the WAN interface. The ISR gateway can ping the host on the lan and get translated to the external public network.
Relevent Config -
ip vrf T172
rd 172:1
ip cef
interface GigabitEthernet0/0
description PublicWAN
ip address dhcp
ip vrf forwarding T172
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description TrunkTOLANSwitch
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex full
speed 1000
interface GigabitEthernet0/1.172
description T172 Lab Interface
encapsulation dot1Q 172
ip address 172.25.0.1 255.255.255.0
no ip unreachables
ip flow ingress
ip nat inside
no cdp enable
ip nat inside source list T172LAN interface GigabitEthernet0/0 vrf T172 match-in-vrf overload
ip access-list extended T172LAN
permit ip 172.25.0.0 0.0.0.255 any
Troubleshooting -
From ISR G2
ISRG2#ping vrf T172 8.8.8.8 source 172.25.0.1
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 172.25.0.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 96/116/192 ms
ISRG2#ping vrf T172 172.25.0.2 source 172.25.0.1
Sending 5, 100-byte ICMP Echos to 172.25.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
ISRG2#show ip route vrf T172
Routing Table: T172
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 192.168.33.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.33.1
      8.0.0.0/32 is subnetted, 1 subnets
S        8.8.8.8 is directly connected, GigabitEthernet0/0
      172.25.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.25.0.0/24 is directly connected, GigabitEthernet0/1.172
L        172.25.0.1/32 is directly connected, GigabitEthernet0/1.172
      192.168.33.0/32 is subnetted, 2 subnets
C        192.168.33.1 is directly connected, GigabitEthernet0/0
C        192.168.33.28 is directly connected, GigabitEthernet0/0
ISRG2#show ip nat translations vrf T172
Pro Inside global      Inside local       Outside local      Outside global
icmp 192.168.33.28:228 172.25.0.1:228     192.168.33.1:228   192.168.33.1:228
icmp 192.168.33.28:229 172.25.0.1:229     192.168.33.28:229  192.168.33.28:229
icmp 192.168.33.28:230 172.25.0.1:230     8.8.8.8:230        8.8.8.8:230
icmp 192.168.33.28:231 172.25.0.1:231     198.80.55.1:231    198.80.55.1:231
icmp 192.168.33.28:27432 172.25.0.2:27432 8.8.8.8:27432      8.8.8.8:27432
Thanks in advance for your response!
Hello Will,
Configuration seems OK, but can you provide entire config if there is not something wrong, lets say ACL which deny return traffic.
Can you try to #debug ip nat translat during ping from LAN host to see if IP addresses are translated?
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Vitaliy Zinatov
Level 7
Level 7
Could you show the routing table and network settings thats used on 172,25,0,3 host
Do you tried this variant of command without parameter
match-in-vrf
ip nat inside source list T172LAN interface GigabitEthernet0/0 vrf T172  overload
----------------------------------------------------------- Прошу вас оценивать и отмечать полезные для вас сообщения. Please rate helpful answers.
Thanks Vitally for your response. I truly appreciate it.
I have tried changing the NAT config to your suggestion...
However, i'm still having the same problem. The host is just a regular windows client with a default route to 172.25.0.1.
Hello Will,
Best Regards
Thank Blau for the tip... I think i found a bug. I monitored the output of debug ip nat translat... noticed that the packets where being translated properly. I then decided to add an ACL to the external interface to see if the traffic was being passed. Incredibly it started working... I had full connectivity from the lan host to the external network. I removed the ACL and it stopped. After some testing I found out that if i removed the "log" statement from the outbound ACL it didn't work. Weird.
In conclusion, I added an ACL "permit ip any any log" outbound on the WAN interface. Works. ACL with "permit ip any any" Doesn't work. This work around will be ok for me.
Thanks for all from your suggestions. I'm off to buy a lotto ticket now!
