nat overload does not work
patcbr600
Level 5
Level 5
Hi all,
I have the folowing nat configuration on my catalyst 6509-E with a sup720-10G that does not work, and gives a erros messague:
ip vrf testes
rd 6900:5
interface Vlan1111
description liga
ip vrf forwarding testes
ip address 192.168.63.91 255.255.255.248
ip nat inside
interface GigabitEthernet2/30
switchport mode access
switchport access vlan 1111
ip address 192.168.63.173 255.255.255.248
ip nat outside
ip nat pool teste_pool 192.168.63.173 192.168.63.173 prefix-length 29
ip nat inside source list 16 pool teste_pool vrf testes overload
access-list 16 permit 128.2.21.0 0.0.0.255
ip route vrf testes 192.168.63.185 255.255.255.255 192.168.63.174
This configuration generates the folowing error:
NAT: translation failed (A), dropping packet s=128.2.21.21 d=192.168.63.185
If i change the nat overload to a static nat, everything
Is there any wrong with this configuration ?
paolo bevilacqua
Try using "interface g2/30" instead of "pool test_pool".
Also for a single IP, pool prefix-length should be /32
