NAT/PAT issue: Can't connect to server's routed IP from LAN
Michael Murray
Level 2
Level 2
I have an 1841 router that is translating TCP port 1723 to an MS VPN server on the LAN. This works fine for external users connecting to 24.76.63.107 (WAN interface of router) but users on the LAN (192.168.1.0/24) cannot connect using the external IP address. I'm guessing this has something to do with using the same routed IP for the outgoing translation as well as the incoming translation. How can I configure the router so internal users can connect to the same server using the external IP address? It is useful for troubleshooting.
-mike
Michael Murray
Level 2
Level 2
Config might help....
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname RTR
boot-start-marker
boot-end-marker
card type t1 0 0
logging buffered 4096
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
ip cef
no ip domain lookup
archive
log config
  hidekeys
controller T1 0/0/0
framing esf
linecode b8zs
cablelength long 0db
channel-group 1 timeslots 1-24
interface FastEthernet0/0
description INTERNAL_LAN
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 24.76.63.107 255.255.255.248
ip access-group INBOUND in
ip access-group OUTBOUND out
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 24.76.63.105
ip http server
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.1.3 25 24.76.63.107 25 extendable
ip nat inside source static tcp 192.168.1.3 80 24.76.63.107 80 extendable
ip nat inside source static tcp 192.168.1.7 1723 24.76.63.107 1723 extendable
ip nat inside source static 192.168.1.2 24.76.63.108
ip nat inside source static 192.168.1.20 24.76.63.109
ip access-list extended INBOUND
deny   ip 127.0.0.0 0.255.255.255 any
deny   ip 192.0.2.0 0.0.0.255 any
deny   ip 224.0.0.0 31.255.255.255 any
deny   ip host 255.255.255.255 any
deny   ip 10.0.0.0 0.255.255.255 any
deny   ip 172.16.0.0 0.15.255.255 any
deny   ip 192.168.0.0 0.0.255.255 any
permit icmp any any echo-reply
permit icmp any any unreachable
permit icmp any any time-exceeded
deny   icmp any any
permit udp any eq domain host 24.76.63.107 gt 1023
permit udp any eq domain host 24.76.63.107 eq domain
permit tcp any 24.76.63.104 0.0.0.7 established
permit udp any range 1 1023 24.76.63.104 0.0.0.7 gt 1023
permit tcp any eq ftp-data 24.76.63.104 0.0.0.7 gt 1023
permit udp any gt 1023 24.76.63.104 0.0.0.7 gt 1023
permit tcp any host 24.76.63.107 eq 1723
permit tcp any host 24.76.63.107 eq www
permit tcp any host 24.76.63.107 eq smtp
permit tcp any host 24.76.63.108 eq www
permit tcp any host 24.76.63.109 eq www
permit tcp any host 24.76.63.107 eq telnet
permit gre any host 24.76.63.107
deny   ip any any log
ip access-list extended OUTBOUND
permit tcp host 192.168.1.3 any eq smtp
deny   tcp 192.168.1.0 0.0.0.255 any eq smtp log
deny   tcp 192.168.0.0 0.0.0.255 any eq smtp log
permit ip any any
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
disable-eadi
alias exec sr show run
alias exec s show ip int br
alias exec srt show ip route
alias exec sri show run | i
alias exec srb show run | b
line con 0
logging synchronous
login local
line aux 0
line vty 0 4
exec-timeout 30 0
logging synchronous
login local
transport input telnet
line vty 5 15
login local
scheduler allocate 20000 1000
ntp clock-period 17179867
ntp master 6
ntp server 209.114.111.1
ntp server 138.236.128.112
ntp server 149.20.68.17
ntp server 70.86.250.6
end
RTR#
