NAT translation based on destination network
ru7
I have read multiple documents on Nat-ting but still not able to resolve this.. any help is appreciated.
1. the LAN network (multiple subnets) needs to access server 1(outside)  - NAT translation works fine no issues
2. a subnet from the LAN e.g SUB-TEST currently acceses server1 but I need to change it  to access TESTserver 2 (outside) instead (temporarily)
I dont want to change the original setup .
I am trying to implement NAT on the local router such that
-  any traffic from SUB-TEST that enters the inside interface and is going to Server1 then change the destination and NAT it to TESTServer 2
-  all other LAN traffic is allowed to go to server 1.
hope this makes sense.
i am using a 1941 router for this
cheers,
RP.
tobyarnett
Ruby,
This does make sense but with out a diagram and some IPs I can't give any real specific details for the fix. However it sounds like what you need to do is incorporate a route-map along with you NAT statements. This would allow you to alter the destination as long as the traffic you want to NAT meets all your defined criteria. I could be off on what your needing but maybe you could provide a little more detail on IPS. They can be sample IPs but something to help clarify what your trying to do.
Toby
Sent from Cisco Technical Support Android App
-Toby
Please don't forget to rate any helpful post.
_____________________________________
There are no great limits to growth because there are no limits of human intelligence, imagination, and wonder.
- Ronald Reagan
