NAT translation failed (a)
jazzybrakes
GATEWAY_ROUTER#sh run
Building configuration...
Current configuration : 1755 bytes
! Last configuration change at 13:29:25 GMT Mon Jun 15 2020
! NVRAM config last updated at 13:07:38 GMT Mon Jun 15 2020
version 12.4
service password-encryption
hostname GATEWAY_ROUTER
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$uOWZ$boGRiZVMoU9gX411Z70V.0
no aaa new-model
clock timezone GMT -4
ip source-route
ip dhcp excluded-address 172.168.2.1 172.168.2.10
ip dhcp excluded-address 172.168.1.1 172.168.1.10
ip dhcp pool net-172-168-1
network 172.168.1.0 255.255.255.224
dns-server 8.8.8.8
default-router 172.168.1.1
ip dhcp pool net-172-168-2
network 172.168.2.0 255.255.255.224
default-router 172.168.2.1
dns-server 8.8.8.8
ip cef
archive
log config
hidekeys
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Serial0/0/0
ip address 10.0.0.1 255.255.255.252
ip nat inside
no fair-queue
router ospf 1
log-adjacency-changes
network 10.0.0.0 0.0.0.3 area 0
network 192.168.2.0 0.0.0.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 172.168.2.0 0.0.0.31
access-list 1 permit 172.168.1.0 0.0.0.31
control-plane
banner motd ^C GATEWAY ROUTER AND DHCP SERVER ^C
line con 0
password 7 104D000A0618
login
line aux 0
line vty 0 4
password 7 13061E010803
login
transport input telnet
scheduler allocate 20000 1000
ntp master
end
LOCAL_ROUTER>en
LOCAL_ROUTER#sh run
Current configuration : 1164 bytes
version 12.4
hostname LOCAL_ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip address
shutdown
duplex auto
speed auto
description connection to sub-if
no ip address
duplex auto
speed auto
interface FastEthernet0/1.5
encapsulation dot1Q 5
ip address 172.168.1.1 255.255.255.224
ip helper-address 10.0.0.1
interface FastEthernet0/1.6
encapsulation dot1Q 6
ip address 172.168.2.1 255.255.255.224
ip address 10.0.0.2 255.255.255.252
no fair-queue
router ospf 1
network 172.168.1.0 0.0.0.31 area 0
network 172.168.2.0 0.0.0.31 area 0
ip http server
no ip http secure-server
control-plane
banner motd ^CLOCAL ROUTER CONNECTED TO SWITCH 1, 2 ^C
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
end
9 Replies 9
jazzybrakes
can anyone assist me in figuring why i am getting this NAT translation failure. I did debug ip nat and i got that error. So i am not sure why i am getting it because the configuration looks correct.
does the fa0/1 interface on the gateway router get an IP address?
jazzybrakes
yes fa 0/1 interface is connected directly to the isp router which assigns the interface with an ip address
can you try using  a route-map instead
route-map SDM_RMAP_1 permit 1
match ip address 1
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/1 overload
jazzybrakes
The route map did not work
can you share the " debug ip nat detailed"
and "sh ip nat stat"
jazzybrakes
DEBUGGING
Jun 24 10:54:25.646: mapping pointer available mapping:0
Jun 24 10:54:25.646: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:54:34.809: mapping pointer available mapping:0
Jun 24 10:54:34.809: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:54:44.512: mapping pointer available mapping:0
Jun 24 10:54:44.512: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:54:54.252: mapping pointer available mapping:0
Jun 24 10:54:54.252: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:54:57.367: mapping pointer available mapping:0
Jun 24 10:54:57.367: NAT: i: icmp (192.168.2.39, 2054) -> (192.168.2.13, 62496) [62]
Jun 24 10:55:03.611: mapping pointer available mapping:0
Jun 24 10:55:03.611: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:55:13.498: mapping pointer available mapping:0
Jun 24 10:55:13.498: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:55:22.981: mapping pointer available mapping:0
Jun 24 10:55:22.981: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:55:32.848: mapping pointer available mapping:0
Jun 24 10:55:32.848: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:55:42.620: mapping pointer available mapping:0
Jun 24 10:55:42.620: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:55:51.687: mapping pointer available mapping:0
Jun 24 10:55:51.687: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:55:57.366: mapping pointer available mapping:0
Jun 24 10:55:57.370: NAT: i: icmp (192.168.2.39, 2054) -> (192.168.2.13, 50673) [75]
Jun 24 10:56:00.802: mapping pointer available mapping:0
Jun 24 10:56:00.802: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:56:09.809: mapping pointer available mapping:0
Jun 24 10:56:09.809: NAT: translation failed (A), dropping packet s=192.168.2.39 d=224.0.0.5
Jun 24 10:56:18.989: mapping pointer available mapping:0
NAT STATISTICS
GATEWAY_ROUTER#sh ip nat statistics
Total active translations: 5 (0 static, 5 dynamic; 5 extended)
Peak translations: 8, occurred 00:01:18 ago
Outside interfaces:
FastEthernet0/1
Inside interfaces:
Serial0/0/0
Hits: 9 Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 4
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 1 interface FastEthernet0/1 refcount 5
Appl doors: 0
Normal doors: 0
Queued Packets: 0
Peak translations: 8, occurred 00:02:02 ago
Outside interfaces:
FastEthernet0/1
Inside interfaces:
Serial0/0/0
Hits: 10 Misses: 0
Expired translations: 5
Dynamic mappings:
-- Inside Source
Appl doors: 0
Normal doors: 0
Queued Packets: 0
IP INT BRIEF
FastEthernet0/0 unassigned YES NVRAM administratively down down
FastEthernet0/1 192.168.2.39 YES DHCP up up
Serial0/0/0 10.0.0.1 YES NVRAM up up
NVI0 unassigned YES unset administratively down down
QUESTION: normally when i do natting i always see NVIO is always up but this time it is administratively down down? Could that be affecting the NAT. Because i heard when natting is done is automatically assign an IP address and administratively up up?
jazzybrakes
I have change the route map back to accesslist I was trying some other stuff
jazzybrakes
Well I have figured it out.....
router ospf 1
default-information orginate
ip router 0.0.0.0 0.0.0.0 isp router address
i change the default route and add the default information originate and it worked. i cant believe i forgot tat crucial information. Thank you for all your response
