NAT Translation not working on IOS XE 17
kyoto
I have situation which I apparently do not understand. NAT Translations show 0 in following case:
show ip nat translations Total number of translations: 0
nat-limit statistics:
max entry: max allowed 0, used 0, missed 0
longest chain in local hash: 0, average length 0, chains 0/2048
In-to-out drops: 0 Out-to-in drops: 6
Pool stats drop: 0 Mapping stats drop: 0
Port block alloc fail: 0
IP alias add fail: 0
Limit entry add fail: 0
Configuration:
interface GigabitEthernet0/0/0
ip address dhcp client-id GigabitEthernet0/0/0
ip nat outside
zone-member security Public
negotiation auto
no cdp enable
ip virtual-reassembly
interface Vlan10
ip address 10.0.21.1 255.255.255.0
ip nat inside
zone-member security Private
route-map inside-network permit 10
match ip address routing-tabele
ip access-list extended routig-tabele
10 permit ip 10.0.20.0 0.0.3.255 any
20 permit ip 10.1.20.0 0.0.0.255 any
30 permit ip 10.4.20.0 0.0.0.255 any
40 permit ip 10.0.24.0 0.0.0.255 any
ip nat inside source route-map inside-network interface GigabitEthernet0/0/0 overload
System image file is "bootflash:c1100-universalk9_ias.17.03.02.SPA.bin"
My actual explanation is that NAT is now working althou I think the consfiguration is correct.
Any Ideas ?
Harold Ritter
Hi @kyoto ,
You mistyped the name of the access-list:
Harold Ritter
Hi @kyoto ,
Harold,
thank you very much. Small mistake -> Big Consequences. Lesson learnt : The mistake is so big as the consequences are.
thanks again, Regards kyoto
You are very welcome @kyoto and thanks for the feedback.
