nat, two isp, vpn connection?
david.mijares
Hello Everyone,
I connected three branch office to HQ with cisco ezvpn(Network Extender, no NAT need it) and until that point I'm fine, but my problem is in HQ's Router a Cisco 1941w has two ISP connection which one is a DSL for outgoing internet services and the other one is a Metro-Ethernet connection for incoming services as VPN and email services. When I use just the metro ethernet everything work smoothly as the VPN services and the internet services as well. But at the moment I decide to swap the outgoing internet services to the DSL connection, the VPN slowdowns and create some lag in the internet services.
Can someone explain me why?
My configuration:
interface GigabitEthernet0/0
description DSL Connetion
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 2
interface GigabitEthernet0/1
description Metro Ethernet
ip address 10.10.10.1 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Virtual-Template1 type tunnel
ip unnumbered GigabitEthernet0/1
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
ip nat inside
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 1
ppp authentication chap pap callin
ip nat inside source static tcp 192.168.1.8 80 interface GigabitEthernet0/1 80
ip nat inside source static tcp 192.168.1.8 25 interface GigabitEthernet0/1 25
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
thanks in advanced
lgijssel
Level 9
Level 9
First of all, it is quite likely that the bandwidth over the DSL link is significantly smaller than via the Metro link.
Besides, there a smaller mtu configured on the dialer. This means packets may need to be fragmented in order to take this path. That wil definitely cause things to slowdown as well. The link below describes the potential impact of mtu mismatches and although it discusses mainly GRE, the problem is the same for IPsec tunnels.
http://www.cisco.com/en/US/partner/tech/tk827/tk369/technologies_tech_note09186a0080093f1f.shtml
regards,
Leo
That's correct and I'm aware of that. However, the VPN should work only over the Metro Ethernet connection and this for unknown reason to me is not happening(not exclusive a least).
