09-04-2015 04:26 AM - edited 03-05-2019 02:14 AM
I connected 4 ISP on a Cisco 1841 router to pool the Internet links for my LAN subnets.
My concern is how I can I restrict the LAN like this:
Admin LAN can use the 4 ISP
USERS LAN can use only 2 ISP
Merci
09-04-2015 07:07 AM
can you past your config first.
Cheers,
-miloud griris
09-04-2015 07:53 AM
Hi Miloud,
config below: I'm stuck with the nat part.
### LAN in
interface FastEthernet0/0.300
description ADMIN
encapsulation dot1Q 300
ip address 192.168.0.10 255.255.255.0
ip nat inside
interface FastEthernet0/0.200
description USERS
encapsulation dot1Q 200
ip address 172.16.0.1 255.255.255.0
ip nat inside
interface FastEthernet0/0.100
description Mgmt
encapsulation dot1Q 100
ip address 10.10.0.1 255.255.255.0
### WAN out
description ISP1
ip address dhcp
ip nat outside
description ISP2
ip address dhcp
ip nat outside
description ISP3
ip address dhcp
ip nat outside
interface FastEthernet0/0.40
description ISP4
encapsulation dot1Q 40
ip address dhcp
ip nat outside
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.254
ip route 0.0.0.0 0.0.0.0 192.168.20.254
ip route 0.0.0.0 0.0.0.0 192.168.30.254
ip route 0.0.0.0 0.0.0.0 192.168.40.254
09-04-2015 10:24 AM
I am sure others might have otehr options. But 2 options that quickly popped are below:
1. Use PBR to set 2 of those SP as nexthop/egres interface and apply to USER LAN and leave ADMIN LAN as it is.
2. Use VRFLite - Create a new VRF and move USER LAN to the VRF and leak 2 of the SP default routes to this new VRF and leave ADMIN LAN in global.
-Nagendra
09-04-2015 10:53 AM
Hi Nagendra,
Can you show me an example cos I'm not familiar with PBR and VRF Lite
TA
09-06-2015 12:54 PM
For PBR,
description USERS
ip nat inside
ip policy route-map PBR
access-list 2 permit 172.16.0.0 0.0.0.255
route-map PBR permit 10
match ip address 2
set ip next-hot ISP2 ISP3
For VRFLite
ip vrf USERS
ip vrf forwarding USERS
ip route vrf USERS 0.0.0.0 0.0.0.0 192.168.20.254
ip route vrf USERS 0.0.0.0 0.0.0.0 192.168.30.254
-miloud griris
