Nating and Routing in ISDN Switch
NShukla108
Dear All I have two ISDN Routers and I could Ping from Router B  172.22.22.254 ( Nating IP on Router A with 10.18.10.0 ) the Router A from Router B.
Theer is also Loopback.
I only want to reach 10.18.10.2 PC, which do not have the Default Gateway and is not reachd from Router B.
I would really appricate your efforts and suggestions.
Thank you in advance
Router A
interface Loopback1
 ip address 172.24.254.8 255.255.255.255
interface BRI0
 ip address negotiated
 ip nat outside
 ip virtual-reassembly in
 encapsulation ppp
 dialer map ip 192.168.1.100 name RAM
isdn switch-type basic-net3
 no isdn termination multidrop
 isdn point-to-point-setup
 ppp authentication chap
interface Vlan1
 ip address 10.18.10.254 255.255.255.0
 ip nat inside
ip nat inside source static network 10.18.10.0 172.22.22.0 /24 no-alias
Router B
interface Loopback0
ip address 192.168.1.100 255.255.255.255
 ip nat outside
interface Dialer1
ip unnumbered Loopback0
ip access-group Kunde_in in
ip access-group Kunde_out out
ip nat outside
encapsulation ppp
dialer pool 1
dialer string 001512525252525
dialer-group 1
ppp authentication chap ppp_local
ppp accounting ppp_local
ppp chap hostname RAM
ip route 172.22.22.0 255.255.255.0 Dialer1
ip access-list extended LOOP0
permit ip any 172.22.22.0 0.0.0.255
post the full configurations of both routers. There are no routes on Router A. On Router B, where does:
point to ?
