01-25-2016 10:45 PM - edited 03-05-2019 03:12 AM
Hi all,
I have a interconnection of 3 already deployed switches. the interface between switch 1 and 2 has been configured as a trunk and the interface between switch 2 and 3 as access port.
The problem is my native vlan 1 is not passing through my access ports which i have to use for management purposes also.
Thanks for the help in advance.
01-26-2016 01:13 AM
Hey could you post some outputs maybe the show int trunk from each switch and the show spanning-tree summary , switch should never stop passing vlan 1 as its the control vlan for the switch that handles cdp and stp traffic etc so even when you shut the int vlan down, vlan 1 at L2 should always operates
01-26-2016 03:51 AM
Hi Mark,
I am currently not in the Data Center, but the situation was:
3 switches interconnected ,with one another, 1 & 2 having trunk link between them and 2 and 3 having access interface.
i was not allowed to(Rules) :
-Change/Modify the native vlan 1 although it was not communicating on the switch 1 and 2 which had the trunk interface.
-Or make the access interface to trunk as it was not allowed by the SP.
Could you please provide me with a solution to make another VLAN and converge it to the access ports on switch 3 for management and also keeping in mind the rules mentioned above.
01-26-2016 03:53 AM
Also the switches wee 2960
01-26-2016 11:19 AM
You have not provided much information about this environment. But it seems likely that the access ports that connect switch 2 and 3 are assigned to a vlan that is different from vlan 1. In that case it is expected behavior that vlan 1 traffic will not be forwarded from switch 2 to switch 3. I believe that there are several alternatives for how you could fix this:
- you could change the ports that connect these switches and make then trunk ports.
- if you can not make them trunk ports then perhaps you could change their configuration so that they were access ports in vlan 1.
- if you can not make them access ports in vlan 1 then perhaps you could allocate another pair of ports on the switches and make a second connection between switches and make these ports access ports in vlan 1.
Rick
02-03-2016 04:44 AM
Hi Richard & Mark,
I just got another issue to discuss..:)
I have a network design of a Hotel,considering the Core, Distribution and Access Design, and using ZYXEL Switches in our core.
The Setup is : Main Core Switch (MS-7206S) and Backup Core Switch (MS-7206S) which are Link Aggregated (Etherchannel in Cisco); having two links into one link aggregation
ISSUE:
The backup Core switch does not take over incase the Main core Switch fails/crashes.
Please can you provide me with an idea of what possible could the issues be and their solution
Thanks in advance
Ahmed
