08-16-2020 05:32 AM
hi , i have asr1006 with IOS XE
i try to use NBAR for QOS
i enable it in interface ingress traffic
! interface Port-channel1.27 description ISP encapsulation dot1Q 27 ip address X,X,X,X.2 255.255.255.252 ip nbar protocol-discovery end
but the NBAR not discovery any protocol
BNG-1#sh ip nbar protocol-discovery
Port-channel1.27
Last clearing of "show ip nbar protocol-discovery" counters 01:17:04
Input Output
Protocol Packet Count Packet Count
Byte Count Byte Count
5min Bit Rate (bps) 5min Bit Rate (bps)
5min Max Bit Rate (bps) 5min Max Bit Rate (bps)
Total 0 0
0 0
0 0
0 0i have last one Nbar ver and is active
BNG-1#show ip nbar protocol-pack active Active Protocol Pack: Name: Advanced Protocol Pack Version: 47.0 Publisher: Cisco Systems Inc. NBAR Engine Version: 34 Creation time: Mon Jan 13 14:32:04 UTC 2020 File: flash:pp-adv-asr1k-169.1-34-47.0.0.pack State: Active
i try create class-map with match protocal for example DNS
But is not captured any packet
so the nbar not working
08-16-2020 07:10 AM
- NBAR is not supported on the Port-Channel
M.
08-16-2020 07:37 AM
08-16-2020 07:33 AM
08-16-2020 07:35 AM
BNG-1#sh license feature Feature name Enforcement Evaluation Subscription Enabled Righ tToUse adventerprise yes yes no yes yes advipservices yes yes no no yes ipbase no no no no no avc yes yes no no yes broadband no no no no no broadband_4k no no no no no cube_250 no no no no no cube_250_red no no no no no cube_ent_100 no no no no no cube_ent_100_red no no no no no cube_lab no no no no no Feature name Enforcement Evaluation Subscription Enabled Righ tToUse cube_video_b2btp no no no no no cube_video_b2btp_red no no no no no firewall no no no no no fpi no no no no no fwnat_red yes yes no no yes gtp_addon_aic no no no no no internal_service yes no no no no ipsec yes yes no no yes lisp yes yes no no yes nat64_stateful_2m no no no no no otv yes yes no no yes Feature name Enforcement Evaluation Subscription Enabled Righ tToUse sgt_fw no no no no no sw_redundancy yes yes no no yes vpls yes yes no no yes FoundationSuiteK9 yes yes no no yes AdvUCSuiteK9 yes yes no no yes CUBE-Standard yes yes no no no CUBE-Redundant yes yes no no no appxk9 yes yes no no yes securityk9 yes yes no no yes uck9 yes yes no no yes OC12_wan_interface yes yes no no yes Feature name Enforcement Evaluation Subscription Enabled Righ tToUse OC3_wan_interface yes yes no no yes interface_40g yes no no no no MACSEC1G yes no no no no MACSEC10G yes no no no no MACSEC40G yes no no no no MACSEC100G yes no no no no
hello
thanks for replay
