03-14-2009 06:37 PM - edited 03-04-2019 03:56 AM
In my company i had 32 employees and they are provide with internet access through ADSL connection.
Now i need a router with NAT . Can you please suggest me the best router which is economical and must satisfy my requirments?
03-15-2009 02:59 PM
850 or 870 series router is a low end model but will do.
Data Sheet: Cisco 850 Series Integrated Services Routers
Data Sheet: Cisco 870 Series Integrated Services Routers for Small Offices
03-15-2009 03:18 PM
Thank you for your reply ,i have seen the data sheet of 800 series router ,it is given that recommended number of users are 10.But i have 32 users. Can you please tell me other options.
03-15-2009 04:24 PM
The 800-series router is already End-Of-Sale. The 850/870 are the new generations of ISR's and these should be able to handle IPSec/VPN for 32 or more users without any hassles.
However, if you are still interested in slightly higher, please refer to the following links:
Integrated Service Routers Quick Look
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/isr.pdf
Portable Product Sheets - Routing Performance
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
03-15-2009 05:00 PM
Your performance is likely to be limited by the bandwidth of your ADSL. As long as the router effectively supports that much bandwidth, shouldn't matter whether there are 1 or 10,0000 users. (Of course, the more users, less bandwidth each gets if fairly shared. So, for more bandwidth, for more users, bigger router. [If you wonder how much bandwidth should be available per user, "that depends".])
03-15-2009 04:41 PM
Alternatively, please check out the interactive Cisco Product Advisor: http://www.ciscowebtools.com/ProductAdvisor/
Please rate when applicable.
