Need A Help
pawanharlecisco
Hello Friends,
                    As per  topology attached herewith,  i have 2 ISPs,    ISP1 and ISP2. And i have one Cisco 1841 Router with only 2 Ethernet interfaces.My Lan subnet is 192.168.1.0.
                    My puspose is, i want to configure both ISP1 and ISP2 and my Lan Network on router, without adding any extra interaface. I  also want to configure a nat so that Lan user can go to internet. I wabt to do this using 2 Interfaces.
            Please give me your views and suggestion ,so that i can implement this.
Topology is attached herewith.
Pawan
17 Replies 17
Pawan,
Well, yes, there is... but I am afraid it would incur higher loads on your router and possibly decrease the throughput. But I believe you now need any solution that works.
Okay. Let me show you another possible configuration. Remove all configuration that you have added as a result with your discussion with me, and apply the following:
interface Loopback192
ip address 192.0.2.1 255.255.255.252
ip nat inside
interface FastEthernet0/0
ip address X.X.X.X M.M.M.M secondary ! This is the IP for ISP1
no ip redirects
ip nat outside
ip policy route-map PBR
interface FastEthernet 1/0
ip address Y.Y.Y.Y M.M.M.M ! This is the IP for ISP2
no ip redirects
ip nat outside
access-list 100 deny 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit 192.168.1.0 0.0.0.255 any
ip nat pool ISP1 X.X.X.X X.X.X.X netmask 255.255.255.252
ip nat pool ISP2 Y.Y.Y.Y Y.Y.Y.Y netmask 255.255.255.252
route-map ISP1 permit 10
match ip address 100
match interface FastEthernet0/0
route-map ISP2 permit 10
match interface FastEthernet1/0
route-map PBR permit 10
set interface Loopback192
ip nat inside source route-map ISP1 pool ISP1 overload
ip nat inside source route-map ISP2 pool ISP2 overload
ip route 0.0.0.0 0.0.0.0 ISP1_NEXT_HOP
ip route 0.0.0.0 0.0.0.0 ISP2_NEXT_HOP
After this works, you may optionally enhance it with your SLA configuration, but this should allow you to use both ISPs and NAT to the correct corresponding space.
Let me know if it worked. And please press your senior for the VLAN-capable switch. All these suggestions are very improper hacks.
Best regards,
Peter
Dear Peter,
                 Thankyou so much....Let me try it and will revert to u.
Pawan
Hi Peter,
                Thankyou very much Brother for helping me and guiding me, the way u guide was too good. All the things are working properly.Please take a look for the config mentioned  below.
Policy#sh run
Building configuration...
Current configuration : 1903 bytes
version 12.4
hostname Policy
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
ip sla monitor 1
type echo protocol ipIcmpEcho 10.10.10.1 source-interface FastEthernet0/0
timeout 1000
threshold 2
frequency 3
ip sla monitor schedule 1 life forever start-time now
track 1 rtr 1 reachability
ip nat inside
ip virtual-reassembly
description Connt ISP1
ip address 10.10.10.2 255.255.255.0 secondary
ip address 192.168.4.1 255.255.255.0
no ip redirects
ip nat outside
duplex auto
speed auto
description Connt ISP2
ip address 192.168.3.1 255.255.255.0
no ip redirects
ip nat outside
duplex auto
speed auto
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
no ip http server
ip route 0.0.0.0 0.0.0.0 10.10.10.1 track 1
ip route 0.0.0.0 0.0.0.0 192.168.3.2 10
ip nat pool ISP1 10.10.10.2 10.10.10.2 netmask 255.255.255.252
ip nat pool ISP2 192.168.3.1 192.168.3.1 netmask 255.255.255.252
access-list 100 deny   ip 192.168.4.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 100 permit ip 192.168.4.0 0.0.0.255 any
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
Policy#
Thanks Once Again...
Pawan
