Need assistance configuring a second two port VWIC card
Jeff Wise
I have a 2811 with two single T1 VWIC cards bonded together as a multilink. I installed a two port VWIC T-1 card and unable to configure, running configuration shows !card type command needed for slot/vwic-slot 0/2. When I try to configure the card type, I get the following message, Card in slot 2 was removed or does not support command. Show diag shows WIC Slot 2: VWIC2-2MFT.
Help please.
Jeff Wise
Think I got it, used the following command, card type T1 0 2
