Need BGP on WS-C3850-24T, how to get IP Services image?
aleksa
Hi all,
I'd need to enable BGP on our core switch, so I could peer with VRF provider, so we could manipulate routing updates over redundant uplinks.
Currently, the 3850 stack of 2 runs OSPF.
When I tried to turn on the BGP, I got the following error:
SW(config)#router ?
  bgp       Border Gateway Protocol (BGP)
  eigrp     Enhanced Interior Gateway Routing Protocol (EIGRP)
  isis      ISO IS-IS
  iso-igrp  IGRP for OSI networks
  mobile    Mobile routes
  odr       On Demand stub Routes
  ospf      Open Shortest Path First (OSPF)
  rip       Routing Information Protocol (RIP)
SW(config)#router bgp 65530
Protocol not in this image
SW(config)#
I understood I'd need the IP services image, but can't find one under software downloads.
Also, the listed models for SW downloads are WS-C3850-24TS,  WS-C3850-24TL or  WS-C3850-24TE
while we got:
Switch Ports Model SW Version SW Image Mode
1 32 WS-C3850-24T 03.02.03.SE cat3k_caa-universalk9 INSTALL
2 32 WS-C3850-24T 03.02.03.SE cat3k_caa-universalk9 INSTALL
SW#sh inventory
NAME: "c3xxx Stack", DESCR: "c3xxx Stack"
PID: WS-C3850-24T , VID: V03 , SN: FCW******N
NAME: "Switch 1", DESCR: "WS-C3850-24T"
I understood I'd need the IP services image, but can't find one under software downloads, nor I can find it for "WS-C3850-24T".
Could it be that the "IP Services" image has to be purchased?
SW#show license ?
right-to-use Displays all the RTU licenses.
SW#show license right-to-use
Slot# License name Type Count Period left
1 ipbase permanent N/A Lifetime
License Level on Reboot: ipbase
2 ipbase permanent N/A Lifetime
Many thanks!
Alex
You have to buy the license with the order code "L-C3850-24-S-E". As there are two switches in your stack and all stack-members need to have the same license, you need to buy this item two times.
