Need Clarification on router ACL
Chandhuru
Hello All,
Please clarify my router ACL doubt. Below is my question,
Source - host(server/specific IP)
Destination - any
Port - object-group(service object - it contains tcp/udp ports)
My question is how to add ACL in specific interface. Actually it is inbound traffic.
Can I add this ACL "permit object-group SERVER-PORTS host xx.xx.xx.xx any"?
Chandhuru
9 Replies 9
Chandhuru
Hello All,
Any one can help on this. Its little urgent.
Your valuable information most appreciated.
Thanks in advance.
Chandhuru
I have my doubts about that statement, is it for a router or firewall ASA?
It looks like a firewall ACL line:
Example:
access-list TEST extended permit object-group PROTOCOL host 1.1.1.100 any eq 53
So you will apply it through access-group
access-group <ACL name: TEST> in interface <nameif>
Note: It is applied to the traffic originated into the firewall, for example:
interface g0
nameif LAN
security-level 100
ip address 1.1.1.1 255.255.255.0
no shutdown
access-group TEST in interface LAN
Note: 1.1.1.100 is part of the network 1.1.10/24
On ASA usually is used in only. Im not really sure how it is configured but it should work.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thanks for the reply Julio!
Its for 1921 router.
interface GigabitEthernet0/1.16
 description TEST
 encapsulation dot1Q 16
 ip address 192.168.1.161 255.255.255.240
  ip access-group TEST-in in
ip access-list extended TEST-in
 permit tcp any eq 80 host XX.XX.XX.XX(Here i want to add object group instead of 80 port alone)
 deny   ip any any log
Note: Host(XX.XX.XX.XX) is out of Network so this is inbound connection.
Hope you got answer for your question. Thanks in advance!
Chandhuru
Thank you, yes your config is fine
 description TEST
You can also verify the hits, using:
show access-list TEST
Hello Julio,
I want to add object-group instead of 80 port there in ACL for inbound access.
Service object group SERVER-PORTS
tcp eq www
tcp eq 69
udp eq 6700
udp eq 6800
udp eq 6900
But the thing is not working. For object-group is there any specific syntax for object group.
Hello Julio,
Hope you got my point/question. If not please tell me, I will try to explain more clearly.
Thanks!
Chandhuru
You could have something like:
tcp eq www
tcp eq 69
udp eq 6700
udp eq 6800
udp eq 6900
 permit tcp any any object-group SERVER-PORTS
 permit udp any any object-group SERVER-PORTS
Im not really sure the sintax on router but you can try.
Hello Julio,
I want source port to be opened but in your syntax mentioned like Destination port.
I have already tried. I want source port syntax with object group.
I want to ensure this is possible in router or not?
Thanks!
Chandhuru
Any update on this?
Chandhuru
