12-30-2014 01:49 AM - edited 03-05-2019 12:28 AM
I've got a problem
Cisco 7200 as a Hub
hostname HUB
ip vrf Crypto
 rd 100:1
ip cef
crypto keyring VPN vrf Crypto
  pre-shared-key address 0.0.0.0 0.0.0.0 key cisco
crypto isakmp policy 20
 authentication pre-share
crypto isakmp profile VPN-Crypto
   vrf Crypto
   keyring VPN
   match identity address 0.0.0.0 Crypto
crypto ipsec transform-set dmvpn_ts esp-3des esp-sha-hmac
crypto ipsec profile MGRE
 set transform-set dmvpn_ts
 set isakmp-profile VPN-Crypto
interface Tunnel15
 description DMVPN Tunnel Interface
 bandwidth 1000000
 ip address 10.10.10.1 255.255.255.0
 no ip redirects
 ip mtu 1300
 ip nhrp authentication test123
 ip nhrp map multicast dynamic
 ip nhrp network-id 236
 ip nhrp holdtime 600
 ip nhrp interest none
 ip ospf network point-to-multipoint
 cdp enable
 tunnel source FastEthernet0/0
 tunnel mode gre multipoint
 tunnel key 100001
 tunnel path-mtu-discovery
 tunnel vrf Crypto
 tunnel protection ipsec profile MGRE
interface FastEthernet0/0
 description Connection to Connection to WAN
 ip vrf forwarding Crypto
 ip address 182.15.233.1 255.255.255.252
 speed auto
 duplex auto
router eigrp 1
 address-family ipv4 vrf Crypto
  network 10.10.10.0 0.0.0.255
  autonomous-system 1
 exit-address-family
 auto-summary
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
Spoke:
Spoke#sh run
hostname Spoke
ip cef
crypto keyring VPN
crypto isakmp policy 1
   keyring VPN
interface Tunnel15
 bandwidth 10000
 ip address 10.10.10.2 255.255.255.0
 no ip redirects
 ip mtu 1300
 ip nhrp authentication beeline
 ip nhrp map multicast 182.15.233.1
 ip nhrp map 10.10.10.1 182.15.233.1
 ip nhrp interest 5
 ip nhrp nhs 10.10.10.1
 qos pre-classify
 cdp enable
 tunnel key 100001
 ip address 182.15.233.2  255.255.255.252
 speed auto
 duplex auto
router eigrp 1
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 182.15.233.1
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
Hub can not ping his own interface 182.15.233.1...... What am I doing wrong?
01-05-2015 05:38 AM
Just to be sure - have you tried the command ping vrf Crypto 182.15.233.1 ? Recall that without the vrf keyword, you are routing the pings according to the global routing table, not the Crypto VRF.
If this does not help, can you please post the output of the show ip int brief and show ip route vrf Crypto commands?
Best regards,
Peter
01-26-2015 02:42 AM
Spoke#sh run
Building configuration...
Current configuration : 1879 bytes
! Last configuration change at 14:52:24 UTC Mon Jan 26 2015
version 12.2
hostname Spoke
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
ip tcp synwait-time 5
crypto keyring VPN
   keyring VPN
interface Tunnel15
 bandwidth 10000
 ip address 172.28.236.2 255.255.255.0
 no ip redirects
 ip mtu 1300
 ip nhrp map multicast 172.28.233.1
 ip nhrp map 172.28.236.1 172.28.233.1
 ip nhrp interest 5
 ip nhrp nhs 172.28.236.1
 qos pre-classify
 cdp enable
 tunnel source FastEthernet1/1
 tunnel key 100001
 no ip address
 shutdown
 duplex half
interface FastEthernet1/0
 no ip address
 shutdown
 speed auto
 duplex auto
interface FastEthernet1/1
 ip address 172.28.233.2 255.255.255.252
 speed auto
 duplex auto
router eigrp 1
 network 172.28.236.0 0.0.0.255
no ip http server
ip route 0.0.0.0 0.0.0.0 172.28.233.1
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
HUB#sh run
Current configuration : 2024 bytes
! Last configuration change at 14:52:38 UTC Mon Jan 26 2015
version 12.2
hostname HUB
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip vrf Crypto
 rd 100:1
no ip domain lookup
ip cef
no ipv6 cef
   vrf Crypto
   keyring VPN
interface Tunnel15
 bandwidth 1000000
 ip address 172.28.236.1 255.255.255.0
 no ip redirects
 ip mtu 1300
 cdp enable
 tunnel key 100001
 tunnel vrf Crypto
 no ip address
 shutdown
 duplex half
 no ip address
 shutdown
 speed auto
 duplex auto
 ip address 172.28.233.1 255.255.255.252
 speed auto
 duplex auto
router eigrp 1
  autonomous-system 1
 exit-address-family
 auto-summary
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 stopbits 1
line vty 0 4
 login
end
HUB#
Spoke#ping 172.28.233.1
Sending 5, 100-byte ICMP Echos to 172.28.233.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/48/124 ms
Spoke#ping 172.28.233.2
Sending 5, 100-byte ICMP Echos to 172.28.233.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/5/8 ms
Spoke#ping 172.28.236.1
Sending 5, 100-byte ICMP Echos to 172.28.236.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Spoke#ping 172.28.236.2
Sending 5, 100-byte ICMP Echos to 172.28.236.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/6/8 ms
HUB#ping 172.28.236.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/4 ms
HUB#ping 172.28.236.2
HUB#ping 172.28.233.1
HUB#ping 172.28.233.2
HUB#sh ip route vrf Crypto
Routing Table: Crypto
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      172.28.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.28.233.0/30 is directly connected, FastEthernet1/1
L        172.28.233.1/32 is directly connected, FastEthernet1/1
Spoke#sh ip route vrf Crypto
% IP routing table vrf Crypto does not exist
Spoke#sh ip int br
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0        unassigned      YES unset  administratively down down
FastEthernet1/0        unassigned      YES unset  administratively down down
FastEthernet1/1        172.28.233.2    YES manual up                    up
Tunnel15               172.28.236.2    YES manual up                    up
HUB#
HUB#sh ip int br
FastEthernet1/1        172.28.233.1    YES manual up                    up
Tunnel15               172.28.236.1    YES manual up                    up
12-21-2017 05:01 AM
HUB router is configured for vrf, therefore, the ping should be initiated from the vrf Crypto.
HUB# ping vrf Crypto 172.28.233.2
