Need help about etherchannel and vlan configuration
davidgildas
Hi all,
I had a 2821 cisco router with a lot of vlans on a same interface. This is a Wan router, each vlan is connected to a trunk to my ISP and directly connected to a SDSL oneacces ONE60 modem. I want to replace 2 one 60 in the same location by a 1801 router with 2 WIC-SHDSL-V2 card. Each car can support 4MBit/s on 2 pairs. I want to do etherchannel between vlan 0/3/1.501 and 0/3/1.502 on my 2821 wan router and on this other side between the 2 WIC to obtain a 8MBit/s throuput.
I try to do :
interface Port-channel2
description VPN-2x4MBit/s
ip address 192.168.83.1 255.255.255.0
duplex full
hold-queue 0 in
A part of my conf contains :
interface FastEthernet0/3/1.501
description SDSL-4M-VPN-Lien01
encapsulation dot1Q 501
interface FastEthernet0/3/1.502
description SDSL-4M-VPN-Lien02
encapsulation dot1Q 502
But if I try to add the commande to one of my vlan interface : channel-group 2 mode active
I had channel-group2 on all my vlan shared the same interface.
Do you see an issue ?
Best Regards.
David.
andrew.prince
Level 10
Level 10
That is correct - that is what will happen, all sub-interfaces under the acutal interface will be placed into the EtherChannel.
AFAIK you cannot place individual virtual interfaces into seperate etherchannels, it's based on physical layer 2/layer 3 interfaces.
Ok,
But that's not solve my problem to obtain a best throughput.
Perhaps I don't ask the good qestions. Also, this is my real problem :
My network had a 2821 cisco with a collected SDSL interface (each SDSL is associated to one vlan).
My ISP deliver each link ATM to a specific VLAN on the same trunk interface. I had at this time more than 20 VLANS.
My ISP can supply only 2 wires on SDSL link that provides a throughput of 4MBit/s max
For one client I want to build a bonding between 2 SDSL card to deliver a 8M link. I'll buy a 1841 with 2 WIC-SHDSL-V2 to do that.
For 2 vlans (for example fast 0/3/0.501 and 0/3/0.502) I want to build an agregated link to obtain a throughput of 8MBit/s ATM for my client.
Do you know how I need to process on my cisco 2821 to agregated this 2 vlans ?
Do I need to use bridge interface ?
Also, an other question is it the same process in the CPE 1841 ?
Thanks for your help.
The schema is this :
                                               __________
modem 1801 WIC-1 ----------------| dslam/LAC|------------------ LNS/2801
                    WIC-2 ---------------|                 |                   2vlans 501 and 502
                                             |__________|
David.
