Need help figuring out QoS on a 6509e
spfister336
Level 2
Level 2
We've recently installed a 6509e to replace a 4507R as a core switch. I'm having a bit of trouble getting the QoS settings right. I've got most of it right, I think, but the old config has:
map dscp 32 33 34 35 36 37 38 39 to tx-queue 2
and also:
tx-queue 3
  priority high
on several interfaces. This config was in place before I got here. Can someone give me a hint on how to get this working on the new config?
Thanks!
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
The queuing architecture is different between a 4500 and 6500.  Additionally, 4500 and 6500 QoS features vary based on sups and/or line cards.  So, it's difficult to be precise on how to best convert your prior 4500's configuration to similar 6500 configuration without much more information.
The sup is a 720 with a hot spare. There are 3 48-port copper Gigabit Ethernet modules (WS-X6748-GE-TX), 1 16-port fiber Gigabit Ethernet module (WS-X6516A-GBIC), plus an IDSM2 module.
Disclaimer
Posting
The 6748 and 6516A differ in egress queuing features, 1p3q8t for the former and 1p2q2t for the latter.  (Likely your sup uses the latter too; you didn't specify which sup720.)
The 6500 sends uses an internal CoS to determine which egress queue to use.  You can configure DSCP to internal CoS mappings.
I would highly recommend searching the main Cisco site for QoS and 6500.  You'll find lots of documentation (better than I can explain in a brief post).  (If you're unfamiliar with 4500 QoS features, you can search for those too.)
If you specific questions, post a new question.
