Need help setting up QoS on 1604-R
mmilano008
I currently have a 1601 router that I am replacing with a 1604-R and want to know if anyone can give me some assistance in setting up the new router so that it works the same as the old one, and how can I setup QoS on it for our VoIP phones.
how was the 1601 configured, do you still have the old configuration, and can you post it ? Did you already have a VoIP QoS policy in place on the 1601 ?
A basic VoIP QoS policy on your 1604 could look like this:
1604
interface Ethernet0
service-policy input VOICE in
class-map match-all VoIP
match access-group name Voice_Traffic
policy-map VOICE
class VoIP
set dscp cs5
ip access-list extended Voice_Traffic
permit tcp any any eq 1720
permit udp any any range 16384 32767
HTH,
GP
I do not have access to the 1601 at this time, but it is still currently in use so I do still have the old configuration. Is there a way to download it to the new router?
Also, thank you for the QoS policy. I am completely new to IOS and not sure how to get that into my router. I will give it a shot though. Any other help you can provide would be great!
Thanks again.
Mark
