03-05-2015 04:21 AM - edited 03-05-2019 12:57 AM
Dear Support Community,
We are using a 6509, with a SUB7203BXL.
ROM: System Bootstrap, Version 12.2(17r)SX6, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF8, RELEASE SOFTWARE (fc2)
EDGE01.PRIVATELAYER.COM uptime is 2 years, 39 weeks, 3 days, 23 hours, 16 minutes
Time since EDGE01.PRIVATELAYER.COM switched to active is 2 years, 39 weeks, 3 days, 23 hours, 32 minutes
We contracted with a service provider to obtain a layer 2 circuit to an internet exchange. Once we got the exchange up, we noticed significant packet loss on the circuit. In order to trouble shoot the circuit, the service provider needs to place a "soft loop" on different parts of the circuit so that we can test to see if those parts are creating the problem. Interface configuration is below:
Building configuration...
Current configuration : 257 bytes
interface TenGigabitEthernet9/3
mac-address 0015.c7f5.8934
ip address 80.81.194.9 255.255.252.0
no ip redirects
no ip proxy-arp
ip flow ingress
no keepalive
ipv6 address 2001:7F8::CA8C:0:1/64
no cdp enable
end
I looked at some documentation online, and in most of the documentation there is a command to set the interface to allow for a loopback. However on this interface, the command is not available. Here are the list of commands available on the interface:
.(config)#int t9/3
.(config-if)#?
Interface configuration commands:
access-expression Build a bridge boolean access expression
apollo Apollo interface subcommands
appletalk Appletalk interface subcommands
arp Set arp type (arpa, probe, snap) or timeout
backup Modify backup parameters
bandwidth Set bandwidth informational parameter
bfd BFD interface configuration commands
bgp-policy Apply policy propogated by bgp community string
bridge-group Transparent bridging interface parameters
carrier-delay Specify delay for interface transitions
cdp CDP interface subcommands
channel-group Etherchannel/port bundling configuration
channel-protocol Select the channel protocol (LACP, PAgP)
clns CLNS interface subcommands
cmns OSI CMNS
crypto Encryption/Decryption commands
custom-queue-list Assign a custom queue list to an interface
dampening Enable event dampening
decnet Interface DECnet config commands
default Set a command to its defaults
delay Specify interface throughput delay
description Interface specific description
dlsw DLSw interface subcommands
dot1x Interface Config Commands for 802.1x
dspu Down Stream PU
eou EAPoUDP Interface Configuration Commands
exit Exit from interface configuration mode
fair-queue Enable Fair Queuing on an Interface
flow-sampler Attach flow sampler to the interface
flowcontrol Configure flow operation.
fras DLC Switch Interface Command
glbp Gateway Load Balancing Protocol interface commands
help Description of the interactive help system
hold-queue Set hold queue depth
inter-packet Inter-packet gap
ip Interface Internet Protocol config commands
ipv6 IPv6 interface subcommands
ipx Novell/IPX interface subcommands
isis IS-IS commands
iso-igrp ISO-IGRP interface subcommands
keepalive Enable keepalive
l2protocol-tunnel Tunnel Layer2 protocols
lacp LACP interface subcommands
lan-name LAN Name command
lat LAT commands
link Interface link related commands
llc2 LLC2 Interface Subcommands
load-interval Specify interval for load calculation for an
interface
locaddr-priority Assign a priority group
logging Configure logging for interface
mac-address Manually set interface MAC address
max-reserved-bandwidth Maximum Reservable Bandwidth on an Interface
mls mls sub/interface commands
mop DEC MOP server commands
mpls Configure MPLS interface parameters
mtu Set the interface Maximum Transmission Unit (MTU)
netbios Use a defined NETBIOS access list or enable
name-caching
no Negate a command or set its defaults
ntp Configure NTP
pagp PAgP interface subcommands
platform platform specific interface configuration
power Power configuration
priority-group Assign a priority group to an interface
priority-queue Configure priority scheduling
random-detect Enable Weighted Random Early Detection (WRED) on an
Interface
rate-limit Rate Limit
rcv-queue Configure receive queue(s)
rmon Configure Remote Monitoring on an interface
sap-priority Assign a priority group
service-policy Configure QoS Service Policy
shutdown Shutdown the selected interface
smrp Simple Multicast Routing Protocol interface
subcommands
sna SNA pu configuration
snapshot Configure snapshot support on the interface
snmp Modify SNMP interface parameters
spanning-tree Spanning Tree Subsystem
stack-mib CISCO-STACK-MIB port configuration items
standby HSRP interface configuration commands
storm-control storm configuration
switchport Set switching mode characteristics
sync-restart-delay Sync restart delay for auto negotiation
tag-switching Tag Switching interface configuration commands
tarp TARP interface subcommands
tcam Set tcam priority
timeout Define timeout values for this interface
traffic-shape Enable Traffic Shaping on an Interface or
Sub-Interface
transmit-interface Assign a transmit interface to a receive-only
interface
tx-ring-limit Configure PA level transmit ring limit
udld Configure UDLD enabled or disabled and ignore global
UDLD setting
unidirectional Configure unidirectional mode.
vines VINES interface subcommands
vrrp VRRP Interface configuration commands
wrr-queue Configure weighted round-robin xmt queues
xconnect Xconnect commands
xns XNS interface subcommands
Any help in this matter, or links to appropriate documentation would be greatly appreciated.
Sincerely,
James Prado
Private Layer
