Need help with Cisco 2600 and cable internet connection
groslyunderpaid
Overview: I have an internet connection that when connected directly to my pc, or through an abitrary SOHO wireless router, I can go to speedtest.net and pull down 11.5 Mbps and 3.0 Mbps up.
When I put the cisco router in between my laptop and the cable modem, I only get ~about~ 1.5 Mbps in either direction.
Is there something I don't know about max bandwidth/throughput for this device?
More info:
I noticed the problem on site at a customer location. They had cable internet, but were only pulling about .6 down and .8 up. By accident when performing a test on a another piece of equipment that circumvented the router, I noticed they were getting over 8.0 down. I ended up replacing the router in that location with an 1800 series and now they get their full speed and everything is great. However, I now have another location with the same issue; we just upgraded their internet to 6Mbps wireless, but they can only get a little under 1 going through the router. It is also a 2600. I brought the old router from the first location home, redid the config for my personal set up, and am experiencing the issue described above.
Here is the config as it was in the original location:
RT-KSHD#show run
Building configuration...
Current configuration : 2010 bytes
version 12.2
service timestamps log uptime
service password-encryption
hostname RT-KSHD
enable secret 5 y
username x password 7 y
ip subnet-zero
chat-script DialOut ABORT ERROR "" "AT" OK "ATDT \T" TIMEOUT 60 CONNECT \c
interface Loopback0
ip address 10.255.255.4 255.255.255.255
interface Tunnel0
description GRE Tunnel to HQ
ip address 10.11.254.30 255.255.255.252
tunnel source Ethernet0/0
tunnel destination 172.16.0.254
interface Ethernet0/0
description "Ethernet connection to GTA firewall 172.16.0.12/30"
ip address 172.16.0.14 255.255.255.252
full-duplex
interface Ethernet0/1
description "x LAN 192.168.2.0/24"
ip address 192.168.2.1 255.255.255.0
full-duplex
interface Async65
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 10
async mode dedicated
ppp authentication chap callout
interface Dialer10
ip address 10.100.100.26 255.255.255.252
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 10
dialer remote-name x
dialer idle-timeout 300
dialer string x
dialer-group 1
router ospf 1
log-adjacency-changes
passive-interface Dialer10
network 10.11.254.28 0.0.0.3 area 0
network 192.168.2.0 0.0.0.255 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.13
ip route 1.1.1.1 255.255.255.255 Dialer10
ip route 10.11.0.0 255.255.255.0 Dialer10 190
no ip http server
ip pim bidir-enable
dialer-list 1 protocol ip permit
snmp-server community public RO
line con 0
login local
line aux 0
script dialer DialOut
modem InOut
modem autoconfigure type usr_sportster
transport input all
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
login local
transport input pad v120 telnet rlogin udptn
no scheduler allocate
end
And here is the config as I have modified it to work at home connected directly to my cable modem:
router#show run
Current configuration : 951 bytes
version 12.2
hostname router
enable secret 5 y
ip subnet-zero
no ip domain-lookup
ip name-server x
ip name-server y
ip name-server z
 description "Connection from cisco to belkin"
 ip address dhcp
 ip nat outside
 full-duplex
 description "laptop only network"
 ip address 192.168.3.1 255.255.255.0
 ip nat inside
 full-duplex
ip nat inside source list 1 interface Ethernet0/0 overload
ip classless
no ip http server
ip pim bidir-enable
access-list 1 permit 192.168.3.0 0.0.0.255
line con 0
 login local
line aux 0
line vty 0 4
 login local
end
Show Ver:
Version 12.2(10r)1
cisco 2611
In both instances, the core issue is the same. The bandwidth I can get is no where near what I can get when the router is not in play. Any suggestions?
Richard Burts
Joshua
It might provide helpful information if you would post the output of show ip interface from your router. One thing I am wondering about is whether the router is process switching packets or if one of the better switching paths is being used.
I would observe that the version of IOS that you are running is old. I wonder if a more recent  version of IOS would have corrected some bugs and might have improved performance. But from your description of the history of the router I also wonder if a code upgrade is feasible (do you have a maintenance contract for this router)?
I also wonder about the possibility of duplex mismatch causing poor performance. I notice that both of your interfaces are hard coded for full duplex. This prevents any negotiation of duplex on both interfaces. It is possible that whatever you are connected to (on either or both interfaces) was not able to negotiate and defaulted to half duplex. Duplex mismatch such as I have described will certainly impact performance. I would suggest changing the configuration of both interfaces to enable negotiation of duplex. Give it a try and let us know if things get better.
Rick
Rick
Richard Burts
Joshua
Rick
Rick
I upgraded to latest IOS 12.3.26 for this model; that itself did not make any difference.
I tried all 4 combinations of changing the duplex of the interfaces. After setting the interface plugged directly into my laptop to half, and the interface plugged into the cable modem at half, I attained the best speeds, about 6.5down and 2.7up. This is a world better than what I was getting and so I would have to say that this is at LEAST the issue with the new (test) configuration, and could have something to do with the way it was configured in original environment. IT also gives me something to go on with the problem I'm facing in new environment. I can not see a way to tell it to duplex auto, the commands appear to put it at duplex half if i tell it anything other than duplex full
show ip interface after making the above changes:
Ethernet0/0 is up, line protocol is up
  Internet address is 174.49.140.155/22
  Broadcast address is 255.255.255.255
  Address determined by DHCP
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF Feature Fast switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
  BGP Policy Mapping is disabled
Ethernet0/1 is up, line protocol is up
  Internet address is 192.168.3.1/24
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Network address translation is enabled, interface in domain inside
Given what the other poster said about NAT possibly slowing this router down a little because of it being a low end, I wonder if the duplex changes might correct the original location as it was ~8.5Mbs?
Unless there is something else you see here that can help me squeeze a few more Mbs through this old baby. And no, this one doesn't have a contract (it did at one time, but expired).
Reza Sharifi
Hi Joshua,
A 2611 router has only 10Mb interfaces and pretty slow processor (MPC860).  Also, when you add NAT to it the router gets slower and slower, because NAT is process intensive.  So, there is no way to get 11.5 out of a 10Mb interface.  With all that said, I do not know why you only get 1.5Mb out of 10Mb interface. To me somewhere close to 6 or 7Mb would be a reasonable speed. If you had an extra public IP address to use for your PC,  It would be intersting to know how high you go witout NAT.
Maybe you should replace this router with a faster one too and see if it helps.
Reza
