Need help with PBR with multiple next hop
captainbluff
I am trying to figure out how I can configure PBR with multiple next hop coming from the same source. Router B is preferred.
Router A:
Source:  10.100.0.0/24
Next Hop
Router B: 172.1.1.1/24
Router C: 172.1.1.2/24
acampbell
Joe,
ip cef
access-list 99 permit 10.100.0.0 0.0.0.255
route-map TEST99
set ip next-hop 172.1.1.1
set ip next-hop recursive 172.1.1.2
set interface null0
match ip address 99
This will try the next hop 172.1.1.1 and will
route to that address until it is unavailable then
the recursive next hop is used. If both fail then packets
are dropped by the set interface null0 command. If you do not include
the set interface null0 then packets will be sent to the default route if
available.
For more info see:-
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/12s_pbr.pdf
Alex.
Please rate useful posts.Joe,
Regards, Alex. Please rate useful posts.
