Need help with pix501
ikturalo1981
I need some help with my new pix501 router, the problem is I cannot get it configured, I folow the instructions given in user manuals and stuff, but some how I still cannot use it the way I want, the thing is I want to make sure that everything from inside can go outside no mather what just anything ( as far I understood this is default set)
and to make sure that speciefied ipaddress from outside gets acces on specified port to speciefied host on inside. So I first tryd it with PDM but everytime i made new rule in acl I got some errors, and stuff, so I tryd this time from console and, everything went well but still there is no acces from outside, and this time even after totaal reset I cannot acces pdm anymore. here Is more info about configs.
this is what I did.
1: setting folowing settings
hostname pix
domain-name ew
ip address inside 192.168.2.1 255.255.255.0
ip address outside 192.168.1.17 255.255.255.0
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 192.168.1.254
dhcpd address 192.168.2.2-192.168.2.10 inside
dhcpd dns 192.168.1.254
dhcpd enable inside
ssh 192.168.1.20 255.255.255.0
ssh 192.168.2.2 255.255.255.0 inside
passwd 12345678
access-list outside_access_in permit tcp any host 192.168.1.20 eq 5900
access-group outside_access_in in interface outside
static (inside,outside) tcp 192.168.1.20 5900 192.168.2.2 5900 netmask 255.255.255.255
Here some info from show:
"" pixtest(config)# show route
outside 0.0.0.0 0.0.0.0 192.168.1.254 1 OTHER static
outside 192.168.1.0 255.255.255.0 192.168.1.17 1 CONNECT static
inside 192.168.2.0 255.255.255.0 192.168.2.1 1 CONNECT static
pixtest(config)# ""
""pixtest(config)# show access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 256)
alert-interval 300
access-list outside_access_in; 2 elements
access-list outside_access_in line 1 permit tcp any host 192.168.1.20 eq 5900 (hitcnt=0)
access-list outside_access_in line 2 permit tcp any host 192.168.1.20 eq 5800 (hitcnt=0)
pixtest(config)# ""
""pixtest(config)# show dhcpd
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
pixtest(config)# ""
""pixtest(config)# show ip
System IP Addresses:
Current IP Addresses:
pixtest(config)# ""
"" pixtest(config)# show nat
pixtest(config)# ""
"" pixtest(config)# show access-group
pixtest(config)# ""
I was tryng to make sure that computer with IP : 192.168.1.20(outside) can acces my pc with vnc on port 5900, my pc has ip : 192.168.2.2 inside,
and shh , but does not work too, not from inside not form outside...
what do I do wrong ???
and pdm is not working anymore.
folowing>>>
5 Replies 5
ikturalo1981
pixtest(config)# show config
: Saved
: Written by enable_15 at 11:49:02.670 UTC Fri Mar 2 2007
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd Vyg.xxxxxxxxxx encrypted
hostname pixtest
domain-name ew
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside_access_in permit tcp any host 192.168.1.20 eq 5800
pager lines 24
mtu outside 1500
mtu inside 1500
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.2.2 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
static (inside,outside) tcp 192.168.1.20 5900 192.168.2.2 5900 netmask 255.255.255.255 0 0
static (inside,outside) tcp 192.168.1.20 5800 192.168.2.2 5800 netmask 255.255.255.255 0 0
route outside 0.0.0.0 0.0.0.0 192.168.1.254 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 outside
ssh 192.168.1.0 255.255.255.0 inside
ssh 192.168.2.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxxxxxxxxxxx
I need this :
1. setting the outside to use specific IP/mask/dns (no dhcp)
2. setting inside to use dhcp or specified ip/mask/dns
3. making sure that internet is accesable
4. making sure that some ip's from outside can acces some host's inside on speciefied port's.
5. that all traffic from inside to outside is permitted.
6. that specified IP can login to pix from outside to config it.
please help if you can.
Which bits are not working, everything or outside access.
You say that you are trying to allow access from a computer on the outside with IP 192.168.1.20 to your pc 192.168.2.2.
The statement
does not do this. What this says is to present your internal IP address 192.168.2.2 as 192.168.1.20 to the outside.
Try this to see if it works
static (inside,outside) tcp 192.168.2.2 192.168.2.2 netmask 255.255.255.255
access-list outside_access_in permit tcp host 192.168.1.20 host 192.168.2.2 eq 5900
Let me know if that works.
As far as the internet goes, your outside IP address is 192.168.1.17 which is not routable on the internet so unless there is some other NAT going on somewhere you will not get internet access with this setup.
Jon
Well yes what I'm tryn to do is make sure that pc 192.168.1.20 from outside can acces my pc 192.168.2.2 on inside on port 5900, and there is no special natting, this router have static IP 192.168.1.17 and thats it..
Okay, try what i've said in the previous post and let me know how you get on.
Jon
That didnot work, but you ware near to the right thing,
I did this
access-list outside_access_in permit tcp any host 192.168.1.17 eq 5900
access-list outside_access_in permit tcp any host 192.168.1.17 eq 5800
static (inside,outside) tcp 192.168.1.17 5900 192.168.2.2 5900 netmask 255.255.255.255 0 0
static (inside,outside) tcp 192.168.1.17 5800 192.168.2.2 5800 netmask 255.255.255.255 0 0
this I got from another forum, Cisco engineer helped lillbit, but you ware right only it had to be not on 192.168.2.2 but all to 192.168.1.17.
now I'm going to play with this lil more to understand it, and also try to get the PDM back, cause now its not working anymore.
