Need IP NAT solution
Totardo Tobing
Level 3
Level 3
Hello Guys,
We have 1 unit of 2900 series router and 3 FE interfaces. One interfaces is used as sub-interface (We have 2 IP segment that used this router as their gateway) and other 2 ports as internet link connected to router's provider.
ISP give us 1 Public IP and another ISP give us 1 public address two.
The two internet links is used as active-standby link.
Can you guide how ip nat configuration against this scenario please?
your dynamic PAT could look like the following. Just replace your interface-IDs and tune the NAT-ACL to you needs.
int gig0/1
  ip nat inside
int ser 1/0
  ip nat outside
int ser 1/1
  ip nat outside
ip nat inside source route-map NAT-ISP1 interface Serial1/0 overload
ip nat inside source route-map NAT-ISP2 interface Serial1/1 overload
ip access-list standard INSIDE
  permit 10.10.12.0 0.0.0.255
route-map NAT-ISP1 permit 10
  match ip address INSIDE
  match interface Serial1/0
route-map NAT-ISP2 permit 10
  match interface Serial1/1
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
int gig0/1
  ip nat inside
int ser 1/0
  ip nat outside
int ser 1/1
  ip nat outside
