Need multicast help
millerlw
Level 3
Level 3
I am having trouble getting some multicast traffic across a link.  I have a 3750G setup, with IP routing and IP multicast routing, between two laptops.  This will eventually sit between two networks that cannot be physically connected to each other for security reasons.  I have static joins on the ports but cannot see the multicast traffic on the receiver.  I am attaching the latest config.  The sender(10.10.4.2) sits on gi1/0/24 and the receiver(10.10.3.2) sits on gi1/0/1.  I am using VLC to test this and it will connect if I point the receiver to the address of the sender, but will not receive any multicasts.  The multicast traffic is not making it to the 10.10.3 side, I used wireshark to verify that it was not making it across.
Leonard
millerlw
Level 3
Level 3
This has been fixed
