Need some help with configuration Packet Tracer
Mark0110101
Hi guys,
for a while i'm struggling with a project in packet tracer.
Is there anyone who can help with this? These are the guidelines:
Device and Vlan addressing table
Implementation of the DHCP server
Vlan network implementation
Trank implementation / EternetChanel
RSTP implementation
HSRP implementation
VOIP implementation
NTP implementation
Implementation of NAT
Implementation of ACL Lists
Implementation of Security against network attacks
ssh, a 12 character password user
passwords for operating modes, console, vty, AAA service
mac array protection - Port security implementation
DTP protection
RSTP protection - PortFast and BPDU guard
DHCP server protection (DHCP snooping, DHCP Spoofing)
ARP protection (ARP Spoofing, Dynamic ARP Inspection
cdp and lldp protection
VLAN Hopping protection
broadcast storm control
NTP protection - transmission authentication
Maybe someone has already made a configuration that meets these requirements.
Best regards,
Mark
9 Replies 9
william.brown1
I could definitely use some help with a configuration like this!
what is the context ? What is the project (and the requirements/guidelines) ?
Hi!
Thank you for replying. I have a project with very similar requirements as above. I have been given a sample model 3 topology that has DHCP, Vlan, trunks, RTSP, HSRP, VoIP, NTP, NAT and an ACL list implemented. Also, it should have different levels of protection with it, which are: DTP, RSTP, DHCP (DHCP snooping and spoofing), ARP (ARP spoofing and dynamic ARP inspection)., CDP, LLDP, VLAN Hopping, and NTP.
I have been given no IP addresses or guidelines, just that I have to complete the project along that sample topology.
Do you have an image of the sample topology, or a project (.pkt) file ?
Yes, of course, here it is. However, it doesn't have to be an exact copy, it's just a sample; I can change it if I want.topology.PNG
that looks good enough. I put something together and send it over...
Wow, thank you very much in advance!
I have put together the attached network (saved in version 7.3.1.), based on the topology you suggested. I have completed the configuration for Vlans, trunking, NAT, access lists, VTP, DHCP, HSRP, and NTP. To complete the entire list of technologies involved will take you at least another several hours.
EDIT: I have also added broadcast storm control and port security on the switch end user ports. Two IP phones have been added to the topology, for VoIP.
I don't know what your level of experience is, and in how far the configurations need explanations. Have a look at the project and come back with any questions...
Wow, thank you so much! It is definitely what I needed!
As for the configurations, I don't really have any questions after I have analyzed it. Starting off is definitely the hardest part, so with the rest I can definitely manage. Thank you very much again, you truly are a blessing!
