Need suppport in DMVPN with OSPF and cluster
Hisoma Sama
Greeting
I am trying to build DMVPN MPLS ( it will be L2VPN MPLS ) i dont know if it will make a difference but im using L2 switch from GNS3 it should be the same i guess since the isp im using will not provide L3 or VRF's anyway, my plan to do 2 main Hubs if one fail the other will act as main, in case the whole site fail i want them to redirect to the disaster recovery site until the main site back up then it will redirect again to the main site. but somehow its not working as it should
the issue im facing
ospf taking along time to come up even with "ip ospf dead-interval" and it dont do the fail-over as i mentioned above.
here's my current configs
Hub 1
interface GigabitEthernet0/0/0
 ip address 10.255.255.1 255.255.255.0
 negotiation auto
end
interface Tunnel10
 bandwidth 1000
 ip address 172.30.10.1 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp map multicast dynamic
 ip nhrp network-id 10
 ip nhrp holdtime 10
 ip nhrp registration timeout 3
 ip nhrp redirect
 ip tcp adjust-mss 1360
 ip ospf network point-to-multipoint
 ip ospf dead-interval minimal hello-multiplier 4
 ip ospf 1 area 10
 keepalive 10 3
 tunnel source GigabitEthernet0/0/0
 tunnel mode gre multipoint
 tunnel key 10
 end
Hub 2
 ip address 10.255.255.2 255.255.255.0
 negotiation auto
end
interface Tunnel10
 bandwidth 1000
 ip address 172.30.10.2 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp holdtime 10
 ip nhrp redirect
 ip ospf 1 area 10
 keepalive 10 3
 tunnel key 10
 end
Site-X
ip address 10.255.255.11 255.255.255.0
negotiation auto
end
interface Tunnel10
  ip address 172.30.10.x 255.255.255.0
 no ip redirects
 ip mtu 1400
 ip nhrp map 172.30.10.1 10.255.255.1
 ip nhrp map 172.30.10.2 10.255.255.2
 ip nhrp map multicast 10.255.255.1
 ip nhrp map multicast 10.255.255.2
 ip nhrp map 172.30.10.5 10.255.255.5
 ip nhrp map multicast 10.255.255.5
 ip nhrp holdtime 10
 ip nhrp nhs 172.30.10.2 priority 2 cluster 1
 ip nhrp nhs 172.30.10.5 priority 3 cluster 1
 ip nhrp nhs 172.30.10.1 cluster 1
 ip nhrp nhs cluster 1 max-connections 10
 ip nhrp nhs fallback 60
 ip nhrp shortcut
 ip ospf 1 area 10
 keepalive 10 3
 cdp enable
 tunnel key 10
 end
im appreciating any help in this matter
9 Replies 9
change the OSPF network type to broadcast and adjust the priority on the hubs and the spoke (changes marked in bold):
Hub 1
negotiation auto
end
interface Tunnel10
bandwidth 1000
no ip redirects
ip mtu 1400
ip nhrp holdtime 10
ip nhrp redirect
ip ospf network broadcast
ip opsf priority 255
ip ospf 1 area 10
keepalive 10 3
tunnel key 10
end
Hub 2
negotiation auto
end
interface Tunnel10
bandwidth 1000
no ip redirects
ip mtu 1400
ip nhrp holdtime 10
ip nhrp redirect
ip ospf priority 254
ip ospf 1 area 10
keepalive 10 3
tunnel key 10
end
Site-X
negotiation auto
end
interface Tunnel10
no ip redirects
ip mtu 1400
ip nhrp holdtime 10
ip nhrp shortcut
ip ospf priority 0
ip ospf 1 area 10
keepalive 10 3
cdp enable
tunnel key 10
end
thanks for your support Georg Pauwen but i tried that the issue i face with it is sometimes the srouter stuck in INIT to it stay down it never come back up unless i remove the tunnel inter face and put it back! any idea why is that?
Can you post the full configs of your routers (both hubs and the spoke) so we can lab this in GNS3 ?
Why do you think that "ip ospf network broadcast" is better? :)
a.alekseev
Level 7
Level 7
Why do you need DMVPN if you have vpls from your provider?
hey Alekseev thanks for you quick response, could you go more into it. should it be a normal routing and ACL and how to do the same fail-over scenario above with vpls.
i tried to convince them with that but they mention it should be encrypted traffic.
most of the designs are for EIGRP but im using OSPF is there any issue with my current config in your opinion? and why its not working with the fail-over
Post the full configs, it is hard to tell what is missing without those...
