Need to Nat just one Host as it goes over the VPN.
NZSHoRtFuSe
Hi All
I've setup a VPN to another office. And they have asked me to Nat the one host that uses it to another IP address as it goes over.
192.168.4.220/24 Host --> Nat to 192.168.255.169 --->VPN----- 192.168.255.168/29----------.><------192.168.255.0/29------VPN<-----Other Router
So more info.
Our local Subnet is 192.168.4.0/24 their local Subnet is 10.12.10.0/24
But they want any 192.168.4.0 traffic hitting their side so that is why the VPN is setup with 192.168.255.168/29 my side and 192.168.255.0/29 their side. So for Traffic to go over the VPN i need to Nat it 192.168.255.168/289 range.
I also need the traffic to go out to the internet using the normal overload nat rule the rest of the 192.168.4.0 host use on the network...
Not sure if this all makes sense!
Thanks for any help!!
Collin Clark
See is this helps-
http://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/14144-static.html
Collin Clark
See is this helps-
Thanks Collin
Gave me the info needed to modify it to work for me :)
Cheers!
Glad to hear you got it working!
