03-06-2025 10:40 PM
I have 2 routers R1 and R2 in the branch location and it's connected to my Datacenter over a point-2-point link from R3 and R4 from the wan side in the Lan side R1 it's connected to the wan sw-1 and from R2 it's connected to wan sw-2 from the wan switch its getting connected in criss-cross connection to my firewall which is acting in active-standby from that its going to my core-switch in criss-cross connection so I have to use the router in active-active mode what configuration need to do done on the router side for wan and Lan
03-07-2025 12:17 AM
Make a small network diagram to understand, let us know what Router model and Switch model you have in both the sides
If the Switch is Layer3 then you can make a IGP or BGP to load-balance across the Links.
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/5212-46.html
03-07-2025 02:58 AM
its a digram and from R1 its connecting to DC R3 over the P2P link and from R2 its connecting to DC R4 over the P2P link
03-08-2025 01:13 AM
I see only 2 Routers in the diagram, where are the other 2 routers ?
Is your firewall Active / Active ? or Active Standby
