Need your advise, how to configure Active/Standby Router , switch 3560 and Access switch?
rechard_david
Dear all,
I would like all of you to recommend how to configure Active/Standby with multi router and core-switch and access switch .
i saw on physical diagram and it has multi link ( cross link ) but i don't know what the protocol they implement and how to configure.
Do you have sample or guide book as the in the attach file.
Note: i don't know how to configure from Access to distribute and distribute to Core-Layer ...
Best Regards,
Rechard
5 Replies 5
rechard_david
Dear all,
Do you have any commend ?
Best Regards,
Rechard
It's too big a question to answer simply.
You are basically asking for a full configuration of all switches and how to set it up and that is a lot of configuration.
Depending on the hardware you have and the placement of the vlans on the access switches there are multiple ways of setting it up.
Cisco have design guides for these sort of things but it depends where you got that diagram from because the type of design you use now may not be the type of design you would have used when that diagram was done.
It is a large subject and there is no easy way to provide a simple answer to your question.
If you have more specific questions then by all means ask.
Jon
Dear Jon,
Sorry for late reply.
Could you advise me on diagram as in the attach file.
i want to configure Active/Standby for Hardware and connection from both Core-switch to both Router . if the primary link down , the Secondary link up . but it the Hardware ( primary ) down all transaction will go to Secondary hardware.
Do you have any idea or sample configuration ?
Best Regards,
Rechard
Joseph W. Doherty
Is your actual network much simpler than your attached diagram?
Tod Larson
Level 3
Level 3
You answer can be found in this series of design guides.
http://www.cisco.com/c/en/us/solutions/enterprise/design-zone/index.html
