Needed Help
ashz14387
In this topology Routers are configured as given in the diagram
Routing Protocols used,
B/W R0, R10, R7 ospf
i have configured tap4 using iptables to nat and forward the traffic to my physical network adapter, which is connected to internet.
my question is when i ping R11 (i.e IP - 14.14.1.3) from the ubuntu machine it was unreachable, why?
Thanks in advance for the reply
5 Replies 5
and other router. are you config static route ? if not you need to config default static route or OSPF between all router
Forgot to mentioned that, i had already configured static NAT between other routers.
internally i can able to ping all the routers in topology ( i.e from R0 to R11, R12 to R9, etc.) but when i try to ping 14.14.1.3 from my ubuntu machine it was unreachable
Hello
So you have NAT running on all 3 rtrs (rtr0-7-11)  and Tap4 is external to the rest of the network , if so do you have a nat statement for the external hosts to reach 14.14.1.3
Can you share the configuration of the rtrs please?
Kind Regards
Paul
Nat (1).pngfor ubuntu it see mapped IP and it reachable
but for R11 it must know how it can reachable ubuntu, you need static route in R11 point to R10
 If your Ubuntu is using IP address 168.224.1.x, the only thing you need to add this network to the OSPF on R0.
But, if you are ping from another interface (network) from Ubuntu, you need to add a static route in R0, pointing to  Ubuntu and add the command "redistribute static subnets" on the OSPF.
