netflow command does not work on Catalyst 4506-e with supervisor 7L-e
Road7star
I am trying to configure netfow on a catalyst 4506-e with supervisor 7L-e with ISO-XE ( Version 3.04.00.SG), but none of the command are in the IOS. From my research the hardware supports it . When I type
RLS_Core_KY(config)#flow exporter rlsMonitor
% Invalid input detected at '^' marker.
If I type
RLS_Core_KY(config)#ip flow-export destination 10.10.10.56
If I configure in a interface I get the same message too.
Seb Rupik
Hi there,
According to the cisco feature navigator, IOS-XE 3.4.x does not support netflow or flexible netflow:
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
I suggest you update the switch the recommend version 3.6.7E . 3.6.x does support netflow.
https://software.cisco.com/download/release.html?mdfid=283904596&catid=268438038&softwareid=282046477&release=3.6.7E
cheers,
Seb.
