Netflow export issue
Jose Goncalves
Hello.
I am trying to export netflow data from a custumer router to my server, but i don't get any data.
The traffic isn't getting by my firewall, but if i do a traceroute the traffic goes to the server.
I had the same config in differente routers with no problem at all.
the IOS is different in this casa, as it is the only Version 15 i have with netflow.
The routers output:
sh ip flow export
Flow export v9 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Source(1)       10.254.3.14 (Loopback15)
    Destination(1)  10.254.254.35 (9995)
  Version 9 flow records
  279309 flows exported in 9619 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
  0 export packets were dropped due to no fib
  0 export packets were dropped due to adjacency issues
  0 export packets were dropped due to fragmentation failures
  0 export packets were dropped due to encapsulation fixup failures
traceroute 10.254.254.35 sou loop15 port 9995
Tracing the route to
VRF info: (vrf in name/id, vrf out name/id)
  1 81.46.18.1 52 msec 44 msec 52 msec
  2 217.124.115.165 [AS 15525] [MPLS: Labels 599/367 Exp 1] 72 msec 60 msec 60 msec
  3  *  *  *
  4 80.58.78.14 [AS 15525] [MPLS: Labels 17594/367 Exp 1] 48 msec 48 msec 68 msec
  5 81.46.1.254 [AS 15525] [MPLS: Labels 17921/367 Exp 1] 80 msec 60 msec 60 msec
  6  *  *  *
  7 172.31.144.234 [AS 12956] 44 msec 48 msec 56 msec
  8 10.254.254.35 [AS 15525] 56 msec 68 msec 76 msec
#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 17:58 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
SOV_Andujar_PRINC_RT uptime is 2 hours, 52 minutes
System returned to ROM by reload at 17:25:34 PT Wed Jul 3 2013
System restarted at 17:27:06 PT Wed Jul 3 2013
System image file is "usbflash0:c1900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 491520K/32768K bytes of memory.
Processor board ID FCZ17069301
2 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9          FCZ17069301
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
data          datak9        Permanent      datak9
Eloy Pascal
you might want to try a different port on the server.
