Netflow not exporting in 2900 router
prakashpms
Even though I have enabled netflow for all interfaces in Cisco 2900 router, it is not exporting the packets.
Is netflow supported in 2900 router?
#show ip cache flow
IP packet size distribution (0 total packets):
   1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
   .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
    512  544  576 1024 1536 2048 2560 3072 3584 4096 4608
IP Flow Switching Cache, 278544 bytes
  0 active, 4096 inactive, 0 added
  0 ager polls, 0 flow alloc failures
  Active flows timeout in 30 minutes
  Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 34056 bytes
  0 active, 1024 inactive, 0 added, 0 added to flow
  0 alloc failures, 0 force free
  1 chunk, 1 chunk added
  last clearing of statistics never
Protocol         Total    Flows   Packets Bytes  Packets Active(Sec) Idle(Sec)
--------         Flows     /Sec     /Flow  /Pkt     /Sec     /Flow     /Flow
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP  Pkts
2 Accepted Solutions
hi,
mine's a 1941 which i've setup netflow before.
strange indeed. perhaps OP can upgrade his IOS if netflow commands aren't working.
>sh ve
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
1. You might try creating a Loopback and use it as the export source interface.
2. Can you check if "ip cef" is enabled on the router?
3. Analyse "debug ip flow export"
________________ Best regards, MB
15 Replies 15
czaja0000
Please, Dump your configuration .
I suggest to use Flexible Netflow
http://www.cisco.com/en/US/docs/ios-xml/ios/fnetflow/configuration/15-mt/fnf-15-mt-book.html
"Is netflow supported in 2900 router?"
Answer for your question
By Cisco documentation:
Almost  all Cisco devices support NetFlow since its introduction in the 11.1  train of Cisco IOS Software and because of this, NetFlow is most likely  available in any devices in the network.
Table 1. NetFlow Recent Cisco Device Support Matrix
Device
NetFlow (TNF/FNF)
Cisco ISR G1
TNF and FNF
Cisco ISR G2
TNF and FNF
*TNF: Traditional NetFlow FNF: Flexible NetFlow
Link to source: http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6601/prod_white_paper0900aecd80406232.html
Best regards,
MB
Thanks for your reply. Whether it is traditional or flexible, the problem I see is that the packets are not exported. Flexible provides additional features to netflow to export to multiple hosts etc. Also in the recent device support matrix in the URL you had given, 2900 series is not listed. The model I have is 2911. Some of the netflow analyzers like solarwinds mentions 2900 does not support netflow.
So, I am trying to find out whether it is really supported or not supported. Inspite of following the instructions to enable netflow and configuring source and destination, it is not generating network packets.
Any suggestions?
Hello, have you configured the below?
ip flow ingress
ip flow egress
ip flow-export source
ip flow-export version X
ip flow-export destination x.x.x.x 2055
What happens when you do a 'show ip flow export'
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
The steps I have followed are.
interface GigabitEthernet0/2
ip flow ingress
ip flow egress
ip route-cache flow
ip flow-export source GIgabitEtherner0/2
ip flow-export version 5
ip flow-export destination x.x.x.x 9996
wr
The output of
#show ip flow export
Flow export v5 is enabled for main cache
  Export source and destination details :
  VRF ID : Default
    Source(1)       x.x.x.x (GigabitEthernet0/2)
    Destination(1)  x.x.x.x (9996)
  Version 5 flow records
  0 flows exported in 0 udp datagrams
  0 flows failed due to lack of export packet
  0 export packets were sent up to process level
  0 export packets were dropped due to no fib
  0 export packets were dropped due to adjacency issues
  0 export packets were dropped due to fragmentation failures
  0 export packets were dropped due to encapsulation fixup failures
It is not exporting any packet.
Please suggest what could be the reason.
hi,
could you post show run int g0/2?
make sure you've got ip route-cache and ip route-cache cef enabled under your egress/ingress ports.
Hi John,
Here is the output of the interface.
Current configuration : 213 bytes
description ----------connected to Core Switch---------
ip address x.x.x.x x.x.x.x
ip access-group test in
ip flow ingress
ip flow egress
duplex auto
speed auto
end
hi,
ok so you've got an ACL there.
have you tried the commands suggested earlier?
could you remove the ACL first and try to ping the netflow collector server from 2911?
Hi John,
I have removed the acl and the ping is successful to the netflow collector before and after the acl removal. Still it is not exporting.
I just tried this on a 2901...
NPEVG01#
NPEVG01#show ip flow export
  VRF ID : Default
    Destination(1)  1.1.1.1 (1)
  268 flows exported in 36 udp datagrams
NPEVG01#
NPEVG01#show run | inc flow
ip flow ingress
ip flow egress
ip flow-export destination 1.1.1.1 1
NPEVG01#
NPEVG01#show ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 14-Jun-11 19:25 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
NPEVG01 uptime is 18 weeks, 15 hours, 54 minutes
System returned to ROM by reload at 15:47:53 UTC Thu Feb 7 2013
System restarted at 15:49:12 UTC Thu Feb 7 2013
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FCZ153290E1
2 Gigabit Ethernet interfaces
2 ISDN Basic Rate interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2901/K9          XXXXXXXX
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
NPEVG01#
NPEVG01#show ip cache flow
IP packet size distribution (3331 total packets):
   .000 .106 .570 .211 .037 .000 .000 .066 .000 .000 .006 .000 .000 .000 .000
  2 active, 4094 inactive, 387 added
  9165 ager polls, 0 flow alloc failures
  1 active, 1023 inactive, 371 added, 371 added to flow
TCP-other            8      0.0       123    98      0.0      35.6      15.5
UDP-other          377      0.0         4   102      0.0       1.7      15.4
Total:             385      0.0         7   101      0.0       2.4      15.4
Gi0/0         172.27.24.182   Local         172.27.24.185   06 F0B2 0016    76
Gi0/0         172.27.24.45    Null          172.27.24.255   11 0089 0089   427
Simply 4 commands and its generating flow exports straight away. It's like its not even active at all in the OP's case. Dont know why this isn't working for Prakash. Very strange & still looking...
What version of IOS are you running?
hi,
>sh ve
Thanks John. After enabling cef explicitly, it worked.
ip cef was not enabled. Since it is mentioned that "ip route-cache flow" will enable cef, I didnt' check. After enable ip cef explicitly, it is exporting the data.
-- Thanks
for the 2921 specific.  I don't think it would be much different for a 2911.  make sure ip cef is turned on.
global commands
ip flow-cache timeout active 1
ip flow-export source Loopback(x) (create this-routable IP)
ip flow-export destination xxx.xxx.xxx.xxx 9996 (we use this port with manageengine)
interface commands
 ip flow ingress
 ip flow egress
output should look like this
<hostname>#sh ip flow export
  VRF ID : Default
    Source(1)       <ip of loopback> (Loopback(x))
    Destination(1)  xxx.xxx.xxx.xxx (9996) (ip of netflow server)
  639724865 flows exported in 164494611 udp datagrams
  164488626 export packets were sent up to process level
  760 export packets were dropped due to no fib
<hostname>#
