network module
amansoi_5
Sir ,
Does Cisco 2611XM router support NM-4T ?
regds,
Aman
ankurbhasin
Level 9
Level 9
Hi Aman,
I don't this it is supported by 2611 router but it is supports by 2691 router.
Have a look at this link which will give you the list of routers who support NM-4T module
http://64.233.161.104/search?q=cache:g56MlxGCAXoJ:www.cisco.com/univercd/cc/td/doc/product/software/ios124/124relnt/xprn124t/124tfeat.pdf+2611XM+support+NM-4T+&hl=en&gl=in&ct=clnk&cd=1
HTH, if yes please rate the post.
Ankur
tdrais
Level 7
Level 7
Only the A/S model is. I think only the 2691 will support the normal nm-4t. Even the 2800's don't support it even thought they support the new wic-4t.
ankurbhasin
Level 9
Level 9
Hi Aman,
Ankur
thanks...
regds,
aman
