Network setup
kmykoo
Hi would someone able to tell me what I am doing wrong? Ive configured a Cisco router 1941 to my supper hub 3 but I can't seem to connect. I have done everything including vergin router being in modem mode . Please see my setup below.
Network design
Superhub 3 ----cisc 1941 router------- Cisco switch
Configuring
Interface Gigabit Ethernet 0/1.( Cable connect to switch)
Description LAN
IP address 82.8.28.1 255.255.255.0
IP nat inside
interface Gigabit Ethernet 0/0 ( cable connect to ISP router)
Description WAN
IP address DHCP
IP nat outside
IP nat inside spurce list 1 interface  G0/0 overload
IP route 0.0.0.0 0.0.0.0 Gigabit Ethernet 0/0
Access-list 1 permit any
IP DHCP pool network LAN network 82.8.28.0 255.255.255.0
Default-router 82.8.28.1
Dns-server 194.168.4.100
6 Replies 6
are your 82.x.x.x real IP addresses ?
Post the full running configuration of your 1941.  Try the changes marked in bold:
Description LAN
IP nat inside
Description WAN
IP address DHCP
IP nat outside
IP nat inside source list 1 interface G0/0 overload
IP route 0.0.0.0 0.0.0.0 Gigabit Ethernet 0/0 dhcp
access-list 1 permit 82.8.28.0 0.0.0.255
ip dhcp excluded-address 82.8.28.1
Yes it' a real IP.
I've changed it to the config file below. But it still won't work. My ISP is vergin media. Can someone please tell me what I am doing wrong?
hostname CiscoRouter
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 194.168.4.100
exit
interface GigabitEthernet0/0
description Connection to Hub
ip address dhcp
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/1
description Connection to LAN
ip nat inside
duplex auto
speed auto
ip nat pool Internet 192.168.1.1 192.168.1.254 netmask 255.255.255.0
ip nat inside source list Internet interface GigabitEthernet0/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
permit ip any any
Don't use any any in the access list, use the actual IP address space of the LAN. Also, post the full configuration of the router, not just snippets...
What do you mean the actual IP address space of the LAN?
the IP address in your original post looked like a public IP address, that is why I was asking. Either way, your access list still doesn't look correct. Post the full configuration of your router, not just snippets...
Hey Thank you so far for your help.
Current configuration : 1442 bytes
version 15.1
hostname main
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool LAN
dns-server 194.168.4.100 194.168.8.100
ip dhcp pool MAIN
license udi pid CISCO1941/K9 sn FCZ1617C5G7
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit any
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
