09-01-2011 05:12 AM - edited 03-04-2019 01:28 PM
Hi there,
is there a command I can run that shows the networks my Router is advertising out it's WAN interface into the BGP cloud to my MPLS providor?
Paul
Solved! Go to Solution.
09-01-2011 05:16 AM
09-01-2011 05:16 AM
show ip bgp neighbors [neighbor IP] advertised-routes
Hope it helps.
09-01-2011 05:21 AM
Hey Collin,
I ran that command but it seems to show all the routes advertised into My Router from the MPLS providor.
I'd like to do the reverse and show all routes being advertised by My Router into the MPLS cloud.
Paul
09-01-2011 05:23 AM
the command Collin posted is the correct one.
Regards.
Alain.
09-01-2011 05:27 AM
Yes thanks very much :-)
