Nexus 9504 QOS (Juniper to cisco)
I am going to migrate existing juniper switch with cisco nexus 9504.
currently we have configured qos on the juniper L3 interfaces.( Access switches and WAN routers)
nexus system qos already classifying the traffic by default. is it recommended to over ride system qos or stick with nexus default system qos?
Need your advise
attaching juniper switch QOS
set class-of-service classifiers dscp DSCP-Set forwarding-class CS6 loss-priority low code-points 110000
set class-of-service classifiers dscp DSCP-Set forwarding-class EF loss-priority low code-points 101110
set class-of-service classifiers dscp DSCP-Set forwarding-class CS4/AF4x loss-priority low code-points 100000
set class-of-service classifiers dscp DSCP-Set forwarding-class CS4/AF4x loss-priority low code-points 100010
set class-of-service classifiers dscp DSCP-Set forwarding-class CS4/AF4x loss-priority low code-points 100100
set class-of-service classifiers dscp DSCP-Set forwarding-class CS4/AF4x loss-priority low code-points 100110
set class-of-service classifiers dscp DSCP-Set forwarding-class CS3/AF3x loss-priority low code-points 011000
set class-of-service classifiers dscp DSCP-Set forwarding-class CS3/AF3x loss-priority low code-points 011010
set class-of-service classifiers dscp DSCP-Set forwarding-class CS3/AF3x loss-priority low code-points 011100
set class-of-service classifiers dscp DSCP-Set forwarding-class CS3/AF3x loss-priority low code-points 011110
set class-of-service classifiers dscp DSCP-Set forwarding-class CS2/AF2x loss-priority low code-points 010000
set class-of-service classifiers dscp DSCP-Set forwarding-class CS2/AF2x loss-priority low code-points 010010
set class-of-service classifiers dscp DSCP-Set forwarding-class CS2/AF2x loss-priority low code-points 010100
set class-of-service classifiers dscp DSCP-Set forwarding-class CS2/AF2x loss-priority low code-points 010110
set class-of-service classifiers dscp DSCP-Set forwarding-class AF1x loss-priority low code-points 001010
set class-of-service classifiers dscp DSCP-Set forwarding-class AF1x loss-priority low code-points 001100
set class-of-service classifiers dscp DSCP-Set forwarding-class AF1x loss-priority low code-points 001110
set class-of-service classifiers dscp DSCP-Set forwarding-class CS0/CS1 loss-priority low code-points 000000
set class-of-service classifiers dscp DSCP-Set forwarding-class CS0/CS1 loss-priority low code-points 001000
set class-of-service forwarding-classes class CS6 queue-num 7
set class-of-service forwarding-classes class EF queue-num 6
set class-of-service forwarding-classes class CS4/AF4x queue-num 5
set class-of-service forwarding-classes class CS3/AF3x queue-num 4
set class-of-service forwarding-classes class CS2/AF2x queue-num 3
set class-of-service forwarding-classes class AF1x queue-num 1
set class-of-service forwarding-classes class CS0/CS1 queue-num 0
set class-of-service scheduler-maps QoS-Scheduler-Map forwarding-class CS6 scheduler Control-Plane
set class-of-service scheduler-maps QoS-Scheduler-Map forwarding-class EF scheduler Voice
set class-of-service scheduler-maps QoS-Scheduler-Map forwarding-class CS4/AF4x scheduler Video
set class-of-service scheduler-maps QoS-Scheduler-Map forwarding-class CS3/AF3x scheduler Signaling/Mission-Critical
set class-of-service scheduler-maps QoS-Scheduler-Map forwarding-class CS2/AF2x scheduler Network-Management/Transaction
set class-of-service scheduler-maps QoS-Scheduler-Map forwarding-class AF1x scheduler Bulk-Traffic
set class-of-service scheduler-maps QoS-Scheduler-Map forwarding-class CS0/CS1 scheduler Standard
@QOS, nexus, switching
0 Replies 0
