NIM configuration
This lab setting is connected with a crossover cable but is still down. Please advise me Thanks.
cisco 4331/Cisco IOS XE Software, Version 16.09.05
controller T1 0/1/0
framing esf
fdl both
clock source network
linecode b8zs
cablelength short 110
channel-group 1 timeslots 1-4
loopback remote esf line csu
GigabitEthernet0/0/0 unassigned YES NVRAM down down
GigabitEthernet0/0/1 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/2 unassigned YES NVRAM down down
Serial0/1/0:1 192.168.10.5 YES manual down down
Serial0/1/1:1 unassigned YES unset down down
cisco 4431/Cisco IOS XE Software, Version 16.06.05
controller T1 0/1/0
framing esf
fdl both
linecode b8zs
Serial0/1/0:1 192.168.10.3 YES manual down down
9 Replies 9
@leyakhath muhammed
Do you mean the serial interface?
Corss over cable is for ethernet interface. Serial interface should serial cable
 Yes, using crossover cable but it is still down.
And you are connecting the Router to what device?
did you try straigh forward cable?
Interconnected cisco 4431/Cisco IOS XE Software, Version 16.06.05, and cisco 4331/Cisco IOS XE Software, Version 16.09.05.
You dont need cross over cable, you can use normal cable.
using a normal cable.
Router#sh int Serial0/1/0:1
Serial0/1/0:1 is down, line protocol is down
Hardware is NIM-4MFT-T1/E1
Internet address is 192.168.10.11/24
MTU 1500 bytes, BW 256 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Last input never, output 00:08:09, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
2 carrier transitions alarm present
Timeslot(s) Used:1-4, subrate: 64Kb/s, transmit delay is 0 flags
This NIM is for Voice solution.
Thanks for your help
@leyakhath muhammed has 2 posts about this. In the other discussion 2 important points were made:
1) if connecting router serial ports back to back then one device must provide clocking. In the posted config both devices try to get clock from the network. So one of the configs must be changed to provide clock.
2) when connecting serial ports back to back you do need a special "serial crossover" cable.
If both of these points are addressed it should allow the connection to work.
Rick
