NME-WAE module - IOS software requirements
CHRISTINE BERNS
We would like to put an NME-WAE-522 module in a router at each side of a WAN link. The IOS feature set currently running in the routers is enterprise base. Do the NME-WAE modules require an upgraded feature set, such as enterprise services or advanced enterprise services?
tstanik
Level 5
Level 5
To support the module NME-WAE module you will need to upgrade the IOS code to 12.4(15)T or above.
