No access to Internet from VLAN to router IP
reynosoalmonte
I have a router as working with IP service voice. This router has a vlan1 as default with IP: 190.x.x.x/24. This is working with PAT to communicate with the ISP.
Then, I have a layer 3 switch with vlan 199 that is the network of my phones and server.
It works very good. But I need to make some change and I can't ping the ip server from the outside of the network with vlan 199.
I try to configure eigrp on both (router and switch) but I have the following message: Neighbor is blocked not on common subnet
What is wrong?
19 Replies 19
post the full configs of both the router and the layer 3 switch...
Hi Georg,
Router IP:
hostname xxx-playero
boot-start-marker
boot-end-marker
no ip domain lookup
ip cef
no ipv6 cef
controller VDSL 0
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
description Link-To-SW-PRINCIPAL
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 190.191.199.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
end
SW-PRINCIPAL:
hostname SW-PRINCIPAL
vrf definition mgmtVrf
no ip domain-lookup
ip dhcp remember
ip dhcp snooping vlan 204
ip dhcp snooping
ip dhcp bootp ignore
ip dhcp conflict resolution
ip dhcp excluded-address 190.191.200.2 190.191.200.8
ip dhcp excluded-address 190.191.203.10
ip dhcp ping timeout 3000
ip dhcp pool 204
network 190.191.204.0 255.255.255.248
default-router 190.191.204.1
dns-server 200.88.127.22 8.8.8.8
ip dhcp pool 202
network 190.191.202.0 255.255.255.240
default-router 190.191.202.1
dns-server 200.88.127.22 200.88.127.23
ip dhcp pool 203
network 190.191.203.0 255.255.255.224
default-router 190.191.203.1
ip dhcp pool 200
network 190.191.200.0 255.255.255.192
default-router 190.191.200.1
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface GigabitEthernet1/1
shutdown
interface GigabitEthernet1/2
shutdown
interface GigabitEthernet1/3
shutdown
interface GigabitEthernet1/4
shutdown
interface GigabitEthernet1/5
description Link to Layer-3-Switch as ISP1
switchport trunk allowed vlan 1,100,101,196,197,199,200,203,205-211,213,215
switchport trunk allowed vlan add 217
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/6
description Link to SW-CAJAS-INTERNET P13
switchport trunk allowed vlan 1,101,209,213,217
interface GigabitEthernet1/7
description Link to SW-CAJAS P9
switchport trunk allowed vlan 1,101,195,202
interface GigabitEthernet1/8
description Link to SW-CENTRAL-IP P3
switchport trunk allowed vlan 1,101,196,199,215,216
interface GigabitEthernet1/9
description Link to SW-USUARIOS P13
switchport trunk allowed vlan 1,101,196,197,200,201,207,208,210-212,215-217
interface GigabitEthernet1/10
description Link to SW-MISC P10
switchport trunk allowed vlan 1,101,195,196,202,203
interface GigabitEthernet1/11
description Link to SW-CONTAB P1
switchport trunk allowed vlan 1,100-102,195-208,210-213,215-217
interface GigabitEthernet1/12
description Link to SW-PAS-15 P7
switchport trunk allowed vlan 1,101,102,196,200,203,205,206,208
interface GigabitEthernet1/13
interface GigabitEthernet1/14
description Link to SERVIDOR-DB-USUARIOS
switchport access vlan 196
switchport mode access
storm-control broadcast level 50.00
interface GigabitEthernet1/15
interface GigabitEthernet1/16
description SERVIDOR-DB-CAJAS
switchport access vlan 195
interface GigabitEthernet1/17
interface GigabitEthernet1/18
description Link-To-SERVER-USUARIOS
switchport access vlan 197
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/19
interface GigabitEthernet1/20
description Link to SERVIDOR-CENTRALIP
switchport access vlan 199
interface GigabitEthernet1/21
interface GigabitEthernet1/22
description Link to SERVIDOR-LABEL
switchport access vlan 198
storm-control broadcast level 20.00
interface GigabitEthernet1/23
interface GigabitEthernet1/24
interface GigabitEthernet1/25
interface GigabitEthernet1/26
interface GigabitEthernet1/27
interface GigabitEthernet1/28
interface GigabitEthernet1/29
interface GigabitEthernet1/30
interface GigabitEthernet1/31
interface GigabitEthernet1/32
interface GigabitEthernet1/33
interface GigabitEthernet1/34
interface GigabitEthernet1/35
interface GigabitEthernet1/36
interface GigabitEthernet1/37
interface GigabitEthernet1/38
description ROUTER-IP
interface GigabitEthernet1/39
interface GigabitEthernet1/40
interface GigabitEthernet1/41
interface GigabitEthernet1/42
interface GigabitEthernet1/43
interface GigabitEthernet1/44
interface GigabitEthernet1/45
interface GigabitEthernet1/46
interface GigabitEthernet1/47
interface GigabitEthernet1/48
interface TenGigabitEthernet1/49
interface TenGigabitEthernet1/50
interface TenGigabitEthernet1/51
interface TenGigabitEthernet1/52
interface Vlan1
description ACCESS-INTERNET
ip address 190.191.192.107 255.255.255.0
interface Vlan101
description Managment
ip address 190.191.101.2 255.255.255.224
interface Vlan195
description VLAN-CAJAS-To-SERVIDOR
ip address 190.191.195.1 255.255.255.252
interface Vlan196
description SERVER-1(DATABASE-USUARIOS)
ip address 190.191.196.1 255.255.255.252
interface Vlan198
description SERVER-3 LABEL ELECT
ip address 190.191.198.1 255.255.255.248
interface Vlan199
description TELEFONOS-IP
ip address 190.191.199.10 255.255.255.0
interface Vlan200
description CAMARAS
ip address 190.191.200.1 255.255.255.192
interface Vlan201
description BALANZAS
ip address 190.191.201.1 255.255.255.240
interface Vlan202
ip address 190.191.202.1 255.255.255.240
interface Vlan203
description NETWORK-VERIFICADORES
ip address 190.191.203.1 255.255.255.224
interface Vlan204
description AP-RECIBIDORES
ip address 190.191.204.1 255.255.255.248
interface Vlan207
description PERSONAL-NI
ip address 190.191.207.1 255.255.255.224
interface Vlan212
description RED-PC-CAFETERIA
ip address 190.191.212.1 255.255.255.252
interface Vlan213
description SV-COMPRAS
ip address 190.191.213.1 255.255.255.252
interface Vlan216
description CONTROL-HORARIO-PERSONAL
ip address 190.191.216.1 255.255.255.248
router eigrp 1
network 0.0.0.0
no ip http server
ip route 0.0.0.0 0.0.0.0 190.191.192.105
ip route 0.0.0.0 0.0.0.0 190.191.192.108 2
event manager applet clear-dhcp-conflict
event timer cron cron-entry "0 0 * * *"
action 1.0 cli command "enable"
action 2.0 cli command "clear ip dhcp conflict *"
end
you currently have configured the below:
Router
interface Vlan1
ip nat inside
Switch
interface Vlan1
The default route on your L3 switch points to 190.191.192.105, so this needs to be the IP address of the Vlan 1 interface on the router. Also, there is no access list 1 for NAT on the Router. So, make the changes marked in bold on the router:
interface Vlan1
ip address 190.191.192.105 255.255.255.0
ip nat inside
access-list 1 permit 190.191.0.0 0.0.255.255
What happens is that I have other router as ISP.
Let's see.
I have two router. One is working as ISP (INTERNET) and other is working as service VoIP. Both are Cisco 800.
Layer 3 switch vlan 1 is doing the route to ISP.
On the router as ISP, vlan 1 is 190.191.192.101/24
If I do this change, I will not have Internet on all the PC's.
post a schematic drawing of your topology including the IP addresses currently in place so we can visualize your network...
See the schematic drawing.
what is the SW-ISP-WITH-HSRP-IP-SLA doing in the network ? What routes do you have configured on there ? I don't see anything HSRP related in the configuration of the other switch, so I don't know what the 'HSRP' in the name means. Is this another Layer 3 switch in your network ? Post the full configuration of that switch as well. I also don't know what you need EIGRP for. And last but not least, all IP addresses in Vlan 1 need to be in the same address space...
the fastest way to help is if you post the full configurations of all devices in your network, make sure the interfaces connecting to other devices have a description saying what device they are connecting to, e.g.:
interface FastEthernet0/0
description Link to SW-PRINCIPAL
Yes, it's a layer 3 switch too. I have configure there hrsp and ip sla working with other layer 3 switch because I have two ISP provider to make a redundancy.
the SW-PRINCIPAL is where I have connect all the servers and other SW's.
You were who help me to configure all this!
this is the config of the layer 3 switch with "HRSP":
track 1 ip sla 1 reachability
interface GigabitEthernet3/0/1
shutdown
interface GigabitEthernet3/0/2
interface GigabitEthernet3/0/3
description Link to Router
interface GigabitEthernet3/0/4
interface GigabitEthernet3/0/5
shutdown
interface GigabitEthernet3/0/6
shutdown
interface GigabitEthernet3/0/7
shutdown
interface GigabitEthernet3/0/8
shutdown
interface GigabitEthernet3/0/9
shutdown
interface GigabitEthernet3/0/10
shutdown
interface GigabitEthernet3/0/11
shutdown
interface GigabitEthernet3/0/12
shutdown
interface GigabitEthernet3/0/13
shutdown
interface GigabitEthernet3/0/14
shutdown
interface GigabitEthernet3/0/15
shutdown
interface GigabitEthernet3/0/16
shutdown
interface GigabitEthernet3/0/17
shutdown
interface GigabitEthernet3/0/18
shutdown
interface GigabitEthernet3/0/19
shutdown
interface GigabitEthernet3/0/20
shutdown
interface GigabitEthernet3/0/21
shutdown
interface GigabitEthernet3/0/22
shutdown
interface GigabitEthernet3/0/23
shutdown
interface GigabitEthernet3/0/24
shutdown
interface GigabitEthernet3/0/25
interface GigabitEthernet3/0/26
interface GigabitEthernet3/0/27
interface GigabitEthernet3/0/28
interface Vlan1
description VLAN_INTERNET
interface Vlan101
ip address 190.191.101.3 255.255.255.224
interface Vlan197
description SERVER-2-PL-USERS
ip address 190.191.197.2 255.255.255.248
standby 8 ip 190.191.197.1
standby 8 priority 150
standby 8 preempt delay minimum 240 reload 300
standby 8 track 1 decrement 50
interface Vlan205
description PLAYERO_PERSONAL
ip address 190.191.205.2 255.255.255.224
standby 3 ip 190.191.205.1
standby 3 priority 150
standby 3 preempt delay minimum 240 reload 300
standby 3 track 1 decrement 50
interface Vlan206
description PLAYERO
ip address 190.191.206.2 255.255.255.240
standby 5 ip 190.191.206.1
standby 5 priority 150
standby 5 preempt delay minimum 240 reload 300
standby 5 track 1 decrement 50
interface Vlan208
description Vlan Internet-Personal
ip address 190.191.208.2 255.255.255.240
standby 2 ip 190.191.208.1
standby 2 priority 150
standby 2 preempt delay minimum 240 reload 300
standby 2 name PERSONAL
standby 2 track 1 decrement 50
interface Vlan209
description VERIFONES
ip address 190.191.209.2 255.255.255.224
standby 7 ip 190.191.209.1
standby 7 priority 150
standby 7 preempt delay minimum 240 reload 300
standby 7 track 1 decrement 50
interface Vlan210
description RENSA
ip address 190.191.210.2 255.255.255.240
standby 10 ip 190.191.210.1
standby 10 priority 150
standby 10 preempt delay minimum 240 reload 300
standby 10 track 1 decrement 50
interface Vlan211
description INTERNET-CAFET
ip address 190.191.211.2 255.255.255.240
standby 9 ip 190.191.211.1
standby 9 priority 150
standby 9 preempt delay minimum 240 reload 300
standby 9 track 1 decrement 50
interface Vlan215
description CONTROL_INT_PERSONAL
ip address 190.191.215.2 255.255.255.224
standby 4 ip 190.191.215.1
standby 4 priority 150
standby 4 preempt delay minimum 240 reload 300
standby 4 track 1 decrement 50
interface Vlan217
description DISASHOP
ip address 190.191.217.2 255.255.255.248
standby 6 ip 190.191.217.1
standby 6 priority 150
standby 6 preempt delay minimum 240 reload 300
standby 6 track 1 decrement 50
router eigrp 1
network 0.0.0.0
eigrp stub connected summary
no ip http server
ip route 0.0.0.0 0.0.0.0 190.191.192.101 track 1
ip route 196.3.74.8 255.255.255.255 190.191.192.101
ip route 196.3.74.8 255.255.255.255 Null0 2
ip sla 1
icmp-echo 196.3.74.8
timeout 15000
frequency 30
ip sla schedule 1 life forever start-time now
ip sla enable reaction-alerts
vstack
login
end
where is the other HSRP device?
where say: description Link-To-ISP2-Delancer. this is a simple router no managment.
this is the other hrsp device:
class-map match-any P2P-PROTOCOL
class-map match-all ANY-TRAFFIC
match access-group name ANY-TRAFFIC
policy-map RATE-LIMIT
class ANY-TRAFFIC
police 1000000 8000 exceed-action drop
interface GigabitEthernet2/0/1
switchport port-security maximum 2
interface GigabitEthernet2/0/2
switchport access vlan 208
interface GigabitEthernet2/0/3
switchport access vlan 213
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
switchport access vlan 207
interface GigabitEthernet2/0/7
switchport access vlan 215
srr-queue bandwidth limit 50
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
speed 10
srr-queue bandwidth limit 15
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
description PC-JONATHAN-ISAIAS
switchport port-security maximum 3
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
description LUIS-SANCHEZ-PC
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
switchport port-security maximum 4
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
description Link to AP ALM00
spanning-tree portfast trunk
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
description DVR-ALMACEN
switchport access vlan 200
interface GigabitEthernet2/0/23
description NANOSTATION-ISAIAS
interface GigabitEthernet2/0/24
description TEL-ISAIAS
interface GigabitEthernet2/0/25
description Link to SW-ALM3
switchport trunk allowed vlan 1,101,197,199,200,204,207,208,213
interface GigabitEthernet2/0/26
description Link To SW-CONTAB
switchport trunk allowed vlan 1,100,101,196-201,204-208,210-213,215,217
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface Vlan1
ip address 190.191.192.108 255.255.255.0
interface Vlan100
description HSRP-PROTOCOL
ip address 190.191.100.2 255.255.255.240
standby 1 ip 190.191.100.1
standby 1 priority 110
standby 1 preempt
interface Vlan101
ip address 190.191.101.4 255.255.255.224
interface Vlan197
ip address 190.191.197.3 255.255.255.248
standby 8 priority 110
standby 8 preempt
interface Vlan205
ip address 190.191.205.3 255.255.255.224
standby 3 priority 110
standby 3 preempt
interface Vlan206
description PLAYERO
ip address 190.191.206.3 255.255.255.240
standby 5 priority 110
standby 5 preempt
interface Vlan208
ip address 190.191.208.5 255.255.255.240
standby 2 priority 110
standby 2 preempt
interface Vlan209
ip address 190.191.209.3 255.255.255.224
standby 7 priority 110
standby 7 preempt
interface Vlan210
description RENSA
ip address 190.191.210.3 255.255.255.240
standby 10 priority 110
standby 10 preempt
interface Vlan211
ip address 190.191.211.3 255.255.255.240
standby 9 priority 110
standby 9 preempt
interface Vlan215
ip address 190.191.215.3 255.255.255.224
standby 4 priority 110
standby 4 preempt
interface Vlan217
ip address 190.191.217.3 255.255.255.248
standby 6 priority 110
standby 6 preempt
router eigrp 1
network 0.0.0.0
no ip http server
ip route 0.0.0.0 0.0.0.0 190.191.192.102 track 1
ip route 0.0.0.0 0.0.0.0 190.191.192.107 2
ip route 45.65.246.1 255.255.255.255 190.191.192.102
ip route 45.65.246.1 255.255.255.255 Null0 2
ip sla 1
icmp-echo 45.65.246.1
timeout 9000
frequency 15
The other interface where say Link-SW-CONTAB (No has any relevant) non SW-ALM3
I am sorry but I am lost. The other HSRP device has:
interface Vlan1
Where is that in your drawing ? I see .101/105/107 but not 108. I also see two Vlan interfaces, one with IP address 190.191.199.254, the other with IP address 190.191.199.10, but one is Vlan 1, and the other Vlan 199.This doesn't mske sense.
Is this a real, working, live network ?
either way, the easiest way to solve this is probably to use policy routing. Match the voice traffic in an access list, the create a route map that matches the access list, and set the next hop to the ISP used for voice.
