06-05-2024 12:48 AM - edited 06-05-2024 01:14 AM
Hi!
I have network with topology that can be seen on screen attached below. I configured switches, configured routers, configured OSPF, vlans, inter vlan routing on R2 etc. Any PC can ping any other no problem. And any PC can ping R2 without any problem. Routers also can ping themselves without any problem. In this regard network works perfectly. But the problem is, that i can't connect any PC to R1 no matter what. There is no communication at all. For example, i can ping 192.168.10.1 from PCF and it works. But if i try to ping 192.168.10.2 i get only "request timed out". What should i do to get this network running properly? Did i forgot to do something important? I've added packet tracer file so you can check there directly what i did wrong.
Solved! Go to Solution.
06-05-2024 12:58 AM
- FYI : Community group for Packet Tracer project questions
M.
06-05-2024 12:58 AM
M.
