No gui on 887VAW built in AP.
LSIArchitects
I have had a replacement router sent out to me due to a fault with the AP.
It had a really old firmware on the AP, which I have updated. Using CCP, I have a wireless network running which is more than I had with the old router.
The issue I have is that there is no gui, just a webpage with a few lines showing commands etc.
I know tha CLI is probably more powerful, but I prefer a GUI.
Looking at the flash of the AP, there seems to be lots of files, which I imagine are part of the gui, so its really just a case of enabling it I would assume.
Does anyone have any ideas?
Thanks.
Leo Laohoo
Make sure your router is booting the built-in AP with autonomous IOS.
Check the config of your router for this command:  service-module wlan-ap 0 bootimage autonomous
That doesnt seem to work.
I try an insert the line in the config using CCP, and I get invalid input detected at marker, its highlighting the - in service-module.
If I run the command in the CLI, I get the invalid input marker at bootimage
Did you try this way?
config t
end
