NO internet connection
Hamid Amir
all interface are up but i can not connect to interne.
can you help please.
the below is my configurartion.
Router#sh run
Building configuration...
Current configuration : 2408 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
crypto pki trustpoint TP-self-signed-4161185151
enrollment selfsigned
ip-address admission max-nodata-conns 3
subject-name cn=IOS-Self-Signed-Certificate-4161185151
revocation-check none
rsakeypair TP-self-signed-4161185151
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.0 192.168.1.99
ip dhcp pool lan-pool
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vtp domain SKYBB
vtp mode transparent
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
ip policy route-map voip
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Dialer0
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
fair-queue
no cdp enable
ppp authentication chap callin
ppp chap hostname ma@plusdsl.net
ppp chap password 0 rground1
ppp pap sent-username ma@plusdsl.net password 0 round1
ppp ipcp dns request
interface BVI1
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http secure-server
ip nat inside source list any interface Dialer0 overload
ip access-list extended any
permit ip any any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
6 Replies 6
Philip D'Ath
Has Dialer0 managed to get an IP address ("show interface Dialer0")?
HI Philip
I managed to make it work with these commands
ip dhcp pool vlan1
import all
dns-server 212.159.13.49 212.159.13.50
lease 0 12
but the proplem i loose them when i reboot the router and i get these errors
import all
% Invalid input detected at '^' marker.
lease 0 12
Press RETURN to get started!
can you help with this please ?
It sounds like you have a had IOS version on that router.  If you have a Cisco maintenance contract like a SmartNet I would upgrade the IOS to something a bit more recent.  12.x code is getting pretty old now.  15.x is the mainstream now.
I have been  using same configuration before and it was working.
thanks
I have made a few adjustments to your configuration (in bold), can you try if you get it to work with these changes ?
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
import all
vtp domain SKYBB
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
atm vc-per-vp 64
pvc 0/38
pppoe-client dial-pool-number 1
no ip address
station-role root
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface Dialer0
ip mtu 1460
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1420
dialer pool 1
dialer-group 1
fair-queue
no cdp enable
interface BVI1
ip nat inside
ip http server
route-map TO_ISP permit 10
 match ip address any
 match interface Dialer 0
ip nat inside source route-map TO_ISP interface Dialer0 overload
permit ip 192.168.1.0 0.0.0.255 any
control-plane
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Hi george
I got erro with pppoe-client dial-pool-number 1 and did not work with the other adjustments.
ip dhcp pool vlan1
import all
lease 0 12
import all
lease 0 12
