no Internet connections on Vlan
karthiksam
hi im a beginner need help to give internet access to vlan 20,40 and to restrict internet from vlan 10, 30.
Current configuration : 2148 bytes
! Last configuration change at 03:54:57 UTC Tue Dec 18 2018
version 15.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 192.168.20.0 192.168.20.10
ip dhcp excluded-address 192.168.40.0 192.168.40.10
ip dhcp pool vlan20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
dns-server 8.8.8.8
ip dhcp pool vlan40
network 192.168.40.0 255.255.255.0
default-router 192.168.40.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO2901/K9 sn FGL211310J6
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description link to Switch
no ip address
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
ip policy route-map CAP-GRE-TUNNEL
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10 native
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface GigabitEthernet0/0.40
encapsulation dot1Q 40
ip address 192.168.40.1 255.255.255.0
interface GigabitEthernet0/1
description WanIP
ip address 172.17.1.229 255.255.255.0
no ip proxy-arp
ip nat outside
ip virtual-reassembly in max-reassemblies 64
duplex auto
speed auto
router rip
version 2
passive-interface GigabitEthernet0/0
network 192.168.0.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 192.168.10.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
johnlloyd_13
Level 9
Level 9
hi,
try enabling 'NAT inside' on the VLAN 20 and VLAN 40 sub-interfaces and re-configure NAT as follows:
 ip nat inside
 ip nat inside
no ip nat inside source list 1 interface GigabitEthernet0/0 overload
no access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.255.255
ip route 0.0.0.0 0.0.0.0 <ISP HOP>
johnlloyd_13
Level 9
Level 9
hi,
 ip nat inside
 ip nat inside
Sorry for the lte reply.... thank john
