no ip mroute-cache
bellocarico
Level 4
Level 4
The command
"no ip mroute-cache"
is added by default on my router config.
What does it do exactly?
olorunloba
Level 10
Level 10
It disables fast switching of multicast packet on the interface on the Cisco router. Check
http://www.cisco.com/en/US/products/ps6441/products_command_reference_chapter09186a00804a8989.html#wp1073851
If you are not routing multicast packets (which is also the default) , it is insignificant.
mheusinger
Level 11
Level 11
generally "mroute" refers to IP multicast.
So it basically does deactivate fast-switching for multicast traffic.
Have a look at
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_command_reference_chapter09186a008017cf23.html#wp1073851
Hope this helps
Martin
