No link between Router and Switch (can't make a connection to any of the switch ports)
Reprovoid
Can't get cisco router and switch to see each other?
When I connect the 2620 router to a 2950 switch no link lights turn on. It's the same when I connect any router to either of the two 2950 switches I have.I can connect to both switch and router from a pc using telnet and the router can connect to a regular tp-link switch.I'm a newbie when It comes to Cisco so any help would be appreciated.Here's the running config for the router and switch.There Is no connection when using any of the switch ports to connect to the fa0/0 of the router.
Router:
version 12.4
hostname ReprovoR2
boot-start-marker
boot-end-marker
enable secret 5 $1$tE9o$76/0ZcMFQ5WnYMNQJTvwI/
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip ftp username reprovo
ip ftp password reprovoforealman
no ip ips deny-action ips-interface
interface FastEthernet0/0
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 192.168.6.2 255.255.255.0
clockrate 128000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router rip
version 2
network 192.168.6.0
network 192.168.10.0
ip classless
no ip http server
no ip http secure-server
control-plane
line con 0
password 1378
login
line aux 0
line vty 0 4
password
login
line vty 5 15
password
login
end
Switch:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Reprovo1
enable secret 5 $1$9sWB$fw8pRBhzFo.89JVtXG5JP1
ip subnet-zero
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface FastEthernet0/25
interface FastEthernet0/26
interface Vlan1
ip address 192.168.10.22 255.255.255.0
no ip route-cache
ip default-gateway 192.168.10.1
ip http server
banner login
line con 0
exec-timeout 0 0
password 1378
login
line vty 0 4
password
login
line vty 5 15
password
login
end
3 Accepted Solutions
cadet alain
Did you choose the correct type of cable because 2950 doesn't support autoMDIX, are the ports on the router not administratively down? if not then issue no shut command under them.
Alain.
hi,
kindly remove this line on your switch and try again:
int f0/1
no switchport mode access
Hi ,
Maybe I haven't had enough coffee this morning but I don't see how the fact  that the port was in access mode was creating the problem as apparently the router had no subinterfaces configured.
Can you explain what obvious stuff i've missed here.
Alain.
18 Replies 18
cadet alain
Alain.
Hi.
I am using the correct type of cable (straight through).All the ports function when connected to another switch or to a pc.
can you post output of sh interface f0/1  status and sh interface f0/1 switchport on the switch as well as sh int f0/0 on the router.
Alain.
Switch
Sh Interface f0/1 status: notconnect  vlan 1  duplex,speed auto type 10/100 base tx
Sh Interface f0/1 switchport:
Name fa0/1
Switchport enabled
Administrative mode: static access
operational mode: down
Administrative Trunking encapsulation dot1q
Negotiation of trunking off
Access mode Vlan 1 (default)
Voice Vlan none
Administrative private vlan host association none
mapping none
trunk native vlan none
trunk encapsulation dot1q
trunk normla Vlan none
Trunk private Vlan none
Trunking Vlans enabled all
Pruning Vlans enabled 2-1001
Capture moded disabled
Capture Vlans allowed all
Protected false
Appliance trust none
Router:F0/0 Is up ,line protocol is down
           internet address 192.168.10.1/24
           Encapsulation ARPA , loopback not set
           Keepalive (10 sec)
           Auto duplex , speed 100 base tx/fx
Sorry , I typed these out.I know how to copy the running config to an ftp server but thats It!
Is It something to do with the encapsulation ?
hi,
int f0/1
Accidentally clicked correct answer.No change.All ports remain In a notconnect state line Is up protocol Is down
so if you connect a PC or another router to this switch port it is ok?
Alain.
Hi ,
Alain.
You've missed the reply below It saying that I accidentally clicked the correct answer button !
It wasn't the correct answer , I still need help! I've posted the interface status for switch and router In the previous posts.
Alain.
Could you use and re-configure your router's FE0/1 and use another switch port?
Lol. No it's not the coffee I did replicate OP's setup in PT with no issue. I suspect a port or HW problem.
Hi.The thing Is all the ports on the switch work when connected to another switch or to a pc.The router fa0/0 also works when connected to a small tp-link switch or to a pc.
Can you try forcing speed and duplex settings to 100-full on both sides.
Alain.
