No more Xmodem in IOS?
zztopping
Level 4
Level 4
I've noticed that in newer IOSs(i'm on a 7204 with 12.4(13d)) that copying configs to and from the router via xmodem are no longer supported...is there a reason for this? Putting a config to a device via xmodem was super convienient...
6 Replies 6
aghaznavi
Level 5
Level 5
could you paste the show version output of your device?
dc-vpn-rtr1#sh ver
Cisco IOS Software, 7200 Software (C7200-IK9O3S-M), Version 12.4(13d), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 06-Aug-07 14:10 by prod_rel_team
ROM: System Bootstrap, Version 12.2(4r)B4, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
dc-vpn-rtr1 uptime is 4 minutes
System image file is "disk0:c7200-ik9o3s-mz.124-13d.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7204VXR (NPE400) processor (revision B) with 491520K/32768K bytes of memory.
Processor board ID 35944966
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
4 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb0_mb1 has a total of 400 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
2 FastEthernet interfaces
125K bytes of NVRAM.
62720K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
dc-vpn-rtr1#copy ?
/erase Erase destination file system.
/noverify Don't verify image signature before reload.
/verify Verify image signature before reload.
archive: Copy from archive: file system
bootflash: Copy from bootflash: file system
cns: Copy from cns: file system
disk0: Copy from disk0: file system
disk1: Copy from disk1: file system
flash: Copy from flash: file system
ftp: Copy from ftp: file system
http: Copy from http: file system
https: Copy from https: file system
ips-sdf Copy from current IPS signature configuration
null: Copy from null: file system
nvram: Copy from nvram: file system
pram: Copy from pram: file system
rcp: Copy from rcp: file system
running-config Copy from current system configuration
scp: Copy from scp: file system
slot0: Copy from slot0: file system
slot1: Copy from slot1: file system
startup-config Copy from startup configuration
system: Copy from system: file system
tftp: Copy from tftp: file system
any update on this?
I don't have the option in any 7200 series, but it available on other platforms.
1200-series APs running 12.4 do not allow xmodem either.
Thats really odd. So you have some other 12.4 routers (non7200) that do still support xmodem?
I do.
